Old 02-24-2006, 06:50 PM   #1
tedbick
1/2 ton to either 3/4 or 1 ton swap
i have a 1977 k 10 and would like to swap to stronger rears what exactly needs to be swapped out to do this?and what are the best rears out there that came stock
tedbick is offline   Reply With Quote
Old 02-24-2006, 07:53 PM   #2
stan79chevy
stan79chevy's Avatar
Re: 1/2 ton to either 3/4 or 1 ton swap
the best would be a d60 front and 14bolt ff rear out of a one ton. a more cost effective swap would be an 8 lug 10 bolt front and a 14bolt ff rear out of a 3/4 ton. the 3/4 ton stuff is a direct bolt in. for the one ton stuff youll have to relocate the spring perches on the rear..the one ton frames are narrower i think..maybe wider...either way a 1 ton 14boltff has the perches 2-3 inches in or out from where they are on a 3/4 ton
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 02-24-2006, 07:55 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
3/4 ton 14bolt full floater....BOLT IN. Simply the best/beefy axle you could put in there for the rear axle. Front would be a Dana 60. Stock in K30's but you also need to get the spring plates with the axle because they are different than the 1/2 and 3/4 ton stuff. Oh and stick with the single rear wheel width stuff (front and rear) unless you want to run H1 beadlocks. The dually front axle has a different front track width (hubs out). 1 ton 14 bolts have the spring mounts in a different spot than the 1/2 and 3/4 tons so unless you want to burn new mounts on find a 3/4 ton version. Both 3/4 and 1 ton full floater 14 bolts are 10.5" ring gears and are virtually identicle (except for the spring mounts)....3/4 ton 14's are just easier to swap.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-28-2006, 01:47 PM   #4
gn4u2c
gn4u2c's Avatar
1 TON STUFF IS THE REAL DEAL. check my parts for sale post.
gn4u2c is offline   Reply With Quote
Old 03-02-2006, 12:49 PM   #5
shelby987
shelby987's Avatar
I know the 14bolt ff axle needs the spring perches moved, but can anyone shed some light on what you have to do to put a srw d60 into the front of your truck (specifically a 70 K20?)
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 03-02-2006, 06:04 PM   #6
b454rat
Unbolt yours, and bolt the 60 in. I had an 84 3/4 that I put a 60 in, and everything bolted in. As stated above, you will need the spring plates, the pass side is differnet. If anybody wants a 60, got 1 for sale.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
