Old 02-26-2006, 01:27 PM   #1
Austin C10
1972 C10 Cheyenne LWB
Power steering went out
I was replacing the top hoses on my radiator and spilled some fluid on the intake manifold where it collected between the mani and the valve covers. With the motor running, I sprayed off the top of the engine. On my next drive, I noticed that the power steering is now not working. I don't think that I even got the power steering pump wet.
The belt is new and tight. The pulley is turning and the fluid is at a reasonable level (maybe a couple of ounces low). Can anyone provide a trouble shooting list? Thanks!
1972 LWB Cheyenne C10 350 TurboHydramatic
Austin C10 is offline   Reply With Quote
Old 02-26-2006, 02:58 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Power steering went out
Either the coolant did it, or it just happened to die at the same time you were working on it. Most likely the former, the latter would be just REAL bad luck.
Antifreeze is very slick stuff, and doesn't just rinse off all the time. I would grab a can of carb cleaner or brake clean, and carefully spray the drive belt and the grooves of the pullies while the engine is running. Tie up any long hippie hair or the neck tie...whech ever you may have, we'd hate to hear about a confrontation with the fan and your face.
I would also recheck the belt tension. Those lower mounted pumps are a total pain in the butt to tighten.
Old 02-26-2006, 02:58 PM   #3
76bonanza
76bonanza's Avatar
is the belt wet? could be sliping.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-26-2006, 03:06 PM   #4
Austin C10
Hippie hair! I wish. I've got more hair on my face than my head.
The pulley on the pump is still turning and the belt is tight. Are you suggesting that when I torque the steering shaft, the pump pulley is no longer being turned? I'll check that out and post the results.
Old 03-01-2006, 03:52 PM   #5
Austin C10
The belt on the pulley isn't slipping. We checked it as I turned at idle, and the belt/pulley remain tight.
Any other ideas or trouble shooting lists? Any ideas about what I'm looking at in terms of repair?
