Old 02-28-2006, 10:25 PM   #1
CochinoFilipino
CochinoFilipino's Avatar
Good donors for Bench Seat?
What trucks have bench seats that are a direct bolt in for 67's?
And which ones are good donors that need little to make work (i.e. seats/frames are already a good hieght, minimal fabrication)?
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 03-01-2006, 09:24 AM   #2
Re: Good donors for Bench Seat?
Honestly,you can have the original seats made as or more comfortable than others with some custom work.IMO opinion that`s way cooler than swapping.
Old 03-01-2006, 01:24 PM   #3
CochinoFilipino
I'd like that. But at some point someone pulled the bench and put in Bucket seats (from a Honda, I think). They are very comfortable and supportive.
But I can't put the childseat between me and my old lady. Back in my rugrat days, I'd probably just sit on Mom's lap. But those days are over. Then again, back then I don't think anyone had buckets seats in a truck.
I'm trying not to spend a bunch of money or time on the truck just yet. So I'm looking for what can be done cheap and easy.
Old 03-01-2006, 01:30 PM   #4
extd56
extd56's Avatar
I have a seat that you can have cheap. It was in a 1971 GMC but looks like it came out of another truck, the seat looks to have been redone but someone modified the legs on it. 40.00 and take it away.
extd56 is offline   Reply With Quote
Old 03-01-2006, 01:48 PM   #5
davidh
davidh's Avatar
That's a good deal. I pulled out a newer ford seat "91-96" from a wrecked 67 I believe and it looked like it bolted in the original holes.
davidh is offline   Reply With Quote
Old 03-01-2006, 01:54 PM   #6
CochinoFilipino
,,,,, It was in a 1971 GMC but looks like it came out of another truck, the seat looks to have been redone but someone modified the legs on it.
Legs modified to fit our trucks? So it will now bolt in? Or it's hacked and I'll have some fixin and fabbin to do? 40 bones sounds pretty good. I just might have to take you up on that.
Old 03-01-2006, 01:55 PM   #7
davidh
davidh's Avatar
I also believe some bucket seats are really comfortable but stand out like a terd in a punch bowl if they are just bolted in and old truck. When the head rests are taken out, recovered in a matching fabric and color it's much more tasteful. I'm thinking of redoing some original seats too. I think some added fabric from a good upholseter will go a long way.
Old 03-01-2006, 02:17 PM   #8
extd56
extd56's Avatar
It needs some fixing on the leg posts, I bought the truck to use for the cab and the seat was in it. They got it redone they said but never got it modified to fit the truck. Here are some pictures of the brackets.The seat is a little bit dirty from sitting in the back of the truck.
Old 03-01-2006, 02:33 PM   #9
CochinoFilipino
Thanks. Let me simmer on that. I won't ask you to hold it for me.
But if I take you up on that, do you think you'll be going to the Good Guys swap meet on the 25th? Vacaville is a bit of a drive. I live on the Mid-Peninsula.
Old 03-01-2006, 03:06 PM   #10
extd56
extd56's Avatar
I am going to that swap meet, unless it is raining.
Old 03-01-2006, 03:12 PM   #11
gn4u2c
gn4u2c's Avatar
i put the rear seat out of a crew in a 70 a few years back as i remember it was minianal work and looked excellent !! btw the rears are the same as fronts if you change the trax .later
gn4u2c is offline   Reply With Quote
Old 03-01-2006, 03:22 PM   #12
cstanley
cstanley's Avatar
i actually just reupholstered my original bench. the one that was in it was from a '96ish ford. it's been in there since '96, and i had forgotten just how big the original was. the ford seat didn't bolt right in. i had to weld a couple of flat plates to the legs to get the holes to line up. imo this is a great seat for our trucks, esp. the earlier ones with squared-off headrests (mine are the taller, rounded ones.) the seat was very comfy and sat a little lower. the back was thinner by a few inches, so it also provided more legroom. for what i spent to redo my old one, i prolly should have just had that one upholstered in factory-matching fabric. plus, the integrated removable cup holder...
you can see the kind i'm talking about below. might have looked great reupholstered...
maybe i still will...someday.
cstanley is offline   Reply With Quote
Old 03-01-2006, 08:36 PM   #13
davidh
davidh's Avatar
Yeah, the seat I pulled out looked like that but's plain vinyl. Its's still in good shape with no tears. yours was from a upper scale trimed truck than mine.
Old 03-01-2006, 10:13 PM   #14
rauto13
saving one more
rauto13's Avatar
I just put a 40/60 split bench from a mid 90's chevy pickup in my 72, the front outer holes lined up perfectly, then had to drill 6 mounting holes for the rest of the seat bolts, bolted them down with fender washers underneath the cab, the only fab work will be the inner front mount for the passenger side, it is too high to use washers as spacers, needs about a 1 inch thick spacer I am going to use a picee of square tubing and bolt that to the cab and then to the seat, I probably have two or three hours total in installing this seat
one other thing is I had to put six flat washers under the rear seat tracks as spacers
really easy to do and sits a bit higher than the factory seat and more comfortable to drive, I am 6 foot and always felt cramped with the factory bench seat
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 03-02-2006, 10:25 AM   #15
About any bench seat will "fit" into your truck.I guess you already have holes drilled for the buckets,so hole drilling isn`t really an issueat this point.Like rauto13 did gets done alot.Plenty of late-model seats in good condition floatin`around,in the right color.
Old 03-02-2006, 10:32 AM   #16
cstanley
cstanley's Avatar
'course stretching the rear of the cab a few inches doesn't hurt either, eh?
Old 03-02-2006, 04:56 PM   #17
randomhero472
randomhero472's Avatar
i just put buckets from an 05' chevy w/middle seat/consol in my 67' yesterday, they fit perfect and have the seat belts built in, took me about 2 hours..i'll post pics asap
randomhero472 is offline   Reply With Quote
Old 03-04-2006, 04:33 PM   #18
oatzy
Careful with that mod. I have been asking about it and if it is not wired right the seatbelts will not stop in a collision. Try and grav the belt and jerk it to see if it stops. Let me know how it works. Also did that just bolt right in?
oatzy is offline   Reply With Quote
Old 03-06-2006, 05:45 PM   #19
CochinoFilipino
This sucks! You offer up a bench seat with no rips for 40 bones and I notice today that the shifter sits further back than the fronts of the bucket seats. The tape below is measuring from the tank.
It probably won't clear the bench seat. Can you pull a tape and measure the base depth? Just in case.
I will be up that way on Saturday to help 'John Fabris' cut up a cab and snake some pieces that I need.
Old 03-06-2006, 06:10 PM   #20
rauto13
saving one more
rauto13's Avatar
just an FYI, that pic in my avvy is photochopped
Old 03-06-2006, 06:11 PM   #21
extd56
extd56's Avatar
The depth on the seat is about 22 inches.
Old 03-10-2006, 01:11 PM   #22
CochinoFilipino
extd56, I sent you a PM with my contact info.
