Old 03-05-2006, 09:39 AM   #1
68Stepbed
68Stepbed's Avatar
Weird chirping noise. What is it?
When I drive my 86, I occasionally have a wierd pulsating, chirping sound coming from the dash. It speeds up as the truck speeds up and slows down as the truck does. My first thought was the speedo or cable. The speedo doesn't jump or bobble at any speed. Would the speedo cable just be dry on the inside or what?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-05-2006, 11:20 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Weird chirping noise. What is it?
Matt, that would be my first guess...pull it and see what you find out.
bigblock73 is offline   Reply With Quote
Old 03-05-2006, 01:32 PM   #3
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Sounds like the culprit to me too.
My 'Burb that I just got had MAJOR chirping.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 03-05-2006, 06:20 PM   #4
marvxyz1
marvxyz1's Avatar
sounds like speedo., but I don't know whether it would be the cable or the actual speed display gauge. Mine sounds like a scratching noise when it is cold outside. I am kind of watching to see what others say about it.
marvxyz1 is offline   Reply With Quote
Old 03-05-2006, 07:49 PM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Pull the cable out and lube it. Just takes a little time and effort. Could also be that the speedometer cable tube is worn out from rubbing and the cable not lubed.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-05-2006, 11:33 PM   #6
68Stepbed
68Stepbed's Avatar
It doesn't make any noise when it's cold. It seems to be after it warms up a little. i'll try to checkit out this week.
Matt
Old 03-06-2006, 10:33 AM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have the same problem. I assume it is a dry cable, but I have not tried to fix it yet. The sound is only annoying, and I am usually too busy fixing stuff that is actually broken to work on things that are only annoying.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
