Old 03-09-2006, 06:59 PM   #1
chevythunder33
chevythunder33's Avatar
Thumbs up cleaning frame
Hello guys would like to get a few ideas on getting all the old mudd built up on the frame off ?
chevythunder33 is offline   Reply With Quote
Old 03-09-2006, 07:07 PM   #2
8bolt
Re: cleaning frame
power washer
8bolt is offline   Reply With Quote
Old 03-09-2006, 07:30 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: cleaning frame
Presoak with detergent & water mix for a few days before starting.
Power washer.
Hammer & chisel if the power washer won't cut it.
If all else fails, two sticks of dynamite, one under the front of the cab, one under the center of the bed. This will leave the hard mud laying in the drive, probably in 2 or 3 pieces. But the truck and frame will be blown clean (clean into the next county)
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-09-2006, 08:02 PM   #4
rtsmith
Re: cleaning frame
Use lots of elbow grease your gonna do alot of scraping after the power wash. Just did that about a month ago.
rtsmith is offline   Reply With Quote
Old 03-09-2006, 08:55 PM   #5
rodnok1
rodnok1's Avatar
Re: cleaning frame
I try and scrape the big stuff off before soaking/power washing.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 03-09-2006, 11:39 PM   #6
1BAD64
1BAD64's Avatar
Re: cleaning frame
see if you have a co-op at your local high school, they might blast it for you.the high school in my town willblast and prime mine for $40.you get a clean frame and the kids get some practice.
1BAD64 is offline   Reply With Quote
Old 03-09-2006, 11:51 PM   #7
bpmcgee
bpmcgee's Avatar
Re: cleaning frame
I used about 10 cans of degreaser and a high-power powerwasher. Then I used a chisel for the parts that were REALLY tough.
Look on the bright side -- all that grease usually keeps the rust off of the frame!
Brian
bpmcgee is offline   Reply With Quote
Old 03-11-2006, 09:01 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: cleaning frame
I always use Gunk Engine Brite at the local car wash on the way home. Then I use a twisted wire cup brush on a 4 inch grinder. It will be clean shiny bare metal in short order.
Get this type, the knotted wire one.
Not this type, they wear out much too fast.
You can get one at any Lowes or Home Depot for just about 15 bucks. I typically get at least 6 months of hard use out of one.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-11-2006, 09:23 PM   #9
Geezer
Geezer's Avatar
Re: cleaning frame
Sand blast it! That get's it really clean.
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
