Old 03-13-2006, 01:55 PM   #1
1LoC10
Insert Title Here
1LoC10's Avatar
3 on the tree bolts?
Is there a specific bolt and nut that holds the shifter arm to the column.. I just have a bolt and nut, and it doesnt fit right it just keeps wiggling and gettting lose till the nut falls off...I have tried washers and geting it tight as hell... but the part on the column that has the hole is rounded and a nut cant fit flush.........is there a special washer or nut for this?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-13-2006, 03:27 PM   #2
shifty
Questionable
shifty's Avatar
Re: 3 on the tree bolts?
wish i could help ya - i gave my shifter linkage away recently. I remember removing it with a wrench - I believe it is a nut.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-13-2006, 03:43 PM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
Yeah, I was just curious if there is some kind of washer that goeas in there though, sense its round and a nuts flat..you know... like a piece thats curved or something to keep it tight
BOBBY
_69 SWB_
Old 03-13-2006, 03:48 PM   #4
shifty
Questionable
shifty's Avatar
does this picture help?
http://www.satellitehead.com/images/...swap%20015.jpg
If not, I have more.
Old 03-13-2006, 04:11 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
im sorry man, i mean the actual lever that you hold to shift... i guess I said it wrong, sorry
BOBBY
_69 SWB_
Old 03-13-2006, 06:31 PM   #6
shifty
Questionable
shifty's Avatar
I don't know how to explain how it's held in there. Mine is held in with a C-shaped hollow cylinder of some sort. Looks almost like a miniature tie rod sleeve.
Old 03-13-2006, 06:32 PM   #7
I have not looked at one for a while, but I swear mine just had a compression pin to hold the lever onto the column. Someone maye have used nut and olt as a substitute when the pin was broken or lost.
Old 03-14-2006, 12:20 AM   #8
Brad
Out of the carpool lane.
Brad's Avatar
You're screwed, ya nut! Get it?!? Oh, sometimes I crack myself up!
Seriously though, it's a compression fit and something I'm dealing with myself on my Camaro. Really, the only thing you can do is get a new column part and a new roll pin thingy. Or maybe use epoxy and glue the bolt and nut onto the column part if this is just a work truck.
Btw, I happen to be selling that column part for $5 + shipping if you're interested. http://67-72chevytrucks.com/vboard/s...d.php?t=191897
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
