Old 03-13-2006, 10:20 PM   #1
nevada70chev
garage/shop heater
hey what are you using for an inexpensive shop/garage heater? pics would be great too.....thanks
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 03-13-2006, 10:46 PM   #2
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: garage/shop heater
I have an old Martin (Dearborn off brand) space hater that was given to me. It's hooked up to a 7 gal RV propane bottle I obtained from a friend who owns an RV dealership. The bottle was old so I got it free. I did have to buy the pressure regulator which was $6. One bottle full costs about $12 and lasts a long time.
With a whopping $18 invested in my heating system, it's lite enough that I can move it to where ever I'm working so I don't have to heat the entire 3400 sqft shop.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 03-13-2006, 10:52 PM   #3
northcountry67
northcountry67's Avatar
Here in northern MN, I use this to heat my 24X24 garage lol.
northcountry67 is offline   Reply With Quote
Old 03-13-2006, 11:03 PM   #4
HotRod71
Short, Fleet, Slammed, V8 Club
3400 sq. ft.????????? Dang that is big. Mine is 1200 and I thought I had a good size place. Once I put the heat in mine I am going to use 220V Ceiling mount heaters. Cheaper than running 110V jobs.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 03-13-2006, 11:39 PM   #5
71SWBChevy
71SWBChevy's Avatar
Have a reddy heat jet heater that was on sale for about 100 at lowes one year. Suppose to heat a 5000 sqft area, doesn't take long to heat our 1200 sq ft shop We have it on a shelf up near the ceiling so the jet isn't constantly blowing on you and an old fan from a school that was shut down to pull the heat down works pretty good, of course our shop is pretty well insulated so even if its below freezing outside once we get it warm inside just turning the heater back on for a few minutes every couple of hours keeps the shop warm if the doors aren't constantly being opened and closed.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 03-13-2006, 11:47 PM   #6
Fastfun
Fastfun's Avatar
I just open my garage door and it is 70 degrees outside. The summer time its a differant story I need a cooler.
Fastfun is offline   Reply With Quote
Old 03-14-2006, 01:01 AM   #7
wibilly
wibilly's Avatar
i have a forced air wood furnace inside a steel lined room in the back of a leantoo i added on one end of the garage. the heat is ducted in the shop and an air return duct filters air and draws it from the shop back through the furnace. when i paint i block off the air return in the shop and draw air from outside through the furnace room where it is pre heated and an exuast fan on the other end of the shop evacuates the paint fumes.the exuast fan has a home built manifold that has 5 4"ports on it. this is where i hook 4"pvc pipe, some perforated and some solid , it just slips togather and can be set up to exuast from any point or points of shop to remove contamints right at sourse like both sides or vehicle both above and below or all on one wall. and of course there is ac in the summer
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-14-2006, 01:29 AM   #8
Skruffy
Skruffy's Avatar
I use one of those Reddy-Heater three burner radiant things hooked onto a propane cylinder. There are a lot of similar options http://www.heatsourcedirect.com/
Skruffy is offline   Reply With Quote
Old 03-14-2006, 11:25 AM   #9
67chevemall
67chevemall's Avatar
Hvac guy! cool...
I have two coleman space heaters that mount on normal propane tanks.
Heats the 20X38 shed nice.....No beer fridge needed in the winter...
Propane fridge in the summer.....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-14-2006, 12:55 PM   #10
zeeklu
I got a forced hot air heater for $20. It runs on fuel oil or diesel and is much more convinent than the propane I was using. It's out of a mobile home and works great. Chris
zeeklu is offline   Reply With Quote
Old 03-14-2006, 01:34 PM   #11
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I rub my hands together REAL fast.
Sorry, I had to.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 03-14-2006, 01:35 PM   #12
Billla
Billla's Avatar
I'm using a 110K BTU propane torpedo heater with a thermostat on the plug. Works pretty well, but needs clearance in back and a LOT in front.
Billla is offline   Reply With Quote
Old 03-14-2006, 03:17 PM   #13
68gmcdually
68gmcdually's Avatar
My new shop is getting a permanent heater called a Hot Dawg heater. It is around the $2000.00 (canadian) mark installed but is well worth it. It doesn't have a standing pilot light, is low profile and is SAFE. Plus we sell and install them at my company. The wifes single car garage is getting a 35,000 btu direct vent heater to keep her and the baby warm. Unfortunately the dog doesn't come with the heater.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 03-14-2006, 03:32 PM   #14
72armyswbtruck
72armyswbtruck's Avatar
HOw about the torch of a heater, watch out rocket man!
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-14-2006, 03:38 PM   #15
biglou55
When i built my two story addition the bottom floor is my two bay garage (24x24 ) I put a force hot air gas furnace in the attic and piped two eight in pipes into my garage which is completly insulated. double pane windows . It stays around 55-60 all winter. I just need ac.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 03-14-2006, 03:43 PM   #16
71SWBChevy
71SWBChevy's Avatar
Sorry, I had to.
Drew
Old 03-15-2006, 02:14 AM   #17
davidh
davidh's Avatar
A friend of mine's brother tried to make a wood burning stove using 55gallon drum barells. If it was warm it was smoky, when it wasn't smoky you were cold.
Not many people had to use heaters this winter. As long as it's 50F I'm okay. Thats what flannels are for.
davidh is offline   Reply With Quote
Old 03-15-2006, 02:26 AM   #18
71SWBChevy
71SWBChevy's Avatar
thats how we use to be to, now the reddy kerosene heater has spoiled me, keep it around 65 in the shop at all time that I am working, perfect for jeans and a T-shirt.
Drew
Old 03-15-2006, 02:27 AM   #19
Skruffy
Skruffy's Avatar
We had one of those several years ago and it put out an AMAZING amount of heat. We never had any smoke problems with it, maybe it was the chimney?
Old 03-15-2006, 05:21 AM   #20
wibilly
wibilly's Avatar
[QUOTE=67chevemall]Hvac guy! cool...
not a hvac guy just a pac-rat most every thing was disgarded by somone else and recycled by me, i love the dumpstore
Old 03-15-2006, 09:48 PM   #21
kelsfine69
18 Till I Die
kelsfine69's Avatar
Heres mine, made it myself... runs on free wood, and only cost me the rod to weld it together. Sometimes to hot to sit by and have to move closer to the door when its -25c
Heats a 26 x 36 Nooo Problem
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-16-2006, 12:09 AM   #22
Bstang
Hey kelsfine69, I see you have a Flamemaster furnace beside that fireplace, must have cracked heat exchangers so you went to wood. Currently I have a wood fireplace in my 20 x 24 shop but I'm getting tired of chopping wood this will be the last winter for wood, going forced air natural gas furnace. Hit the power and instant heat.Wood works great but getting wood takes time away from the real work.
Bstang is offline   Reply With Quote
Old 03-16-2006, 12:52 AM   #23
kelsfine69
18 Till I Die
kelsfine69's Avatar
Hey guess what.... I use the Flame Master as Lazy days.... theres a Truss place down the road that dumps a pick-up load every day...free for the taking
= Free Heat
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-16-2006, 01:16 AM   #24
rkarr
rkarr's Avatar
I actually am a factory rep for Lennox.... The space heaters I can get you....
Very similar to the "hot dawg"...
PM me if you need it in the states...
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 03-16-2006, 01:31 AM   #25
longhorn71
longhorn71's Avatar
mine well be underfloor heated.water lines under the concerte with a boiler heater.the shop is 60x60 we are building
longhorn71 is offline   Reply With Quote
