03-14-2006, 10:50 AM | #1 |
Active Member
Removing front end
I'm getting ready to clean and rebuild the front and rear portions of the chassis on my 67. How many and where are all the bolts to take the whole front end off in one piece? I have the cowl, one bolt through the inner fender into a bracket on the cab and the two bolts at the radiator core support removed. The back end doesn't even budge yet. Do I have to remove the inner fenders? Are there more bolts behind them holding the fenders to the cab?
Also, once I get the front clip off, I think I can handle dis-assembly of the front end (steering and suspension), should I remove the brake lines and fuel lines to clean and paint the inside of the frame, or should I just spray right over them? My plans are to rebuild the entire front and rear suspension, add power steering, and add a disc brake kit and 4/6 drop from ECE. If you guys/gals have any comments or suggestions, please let me know. Thanks
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
03-14-2006, 11:24 AM | #2 |
Just need a couple more parts.
Re: Removing front end
I found I used to take things off my truck and place them either on the floor or on my bench in the order they can off so they would go back on in the same order.
Then I spent $50 on the assembly manuel that shows every nut and bolt washer etc and it was worth it. It gives you a refrence guide when you are tearing pieces apart and gives you a guide to put it back together after it has taken weeks and sometimes longer to get the work done.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
03-14-2006, 11:28 AM | #3 |
Underneath the cowl at the back of the fender at the top they are held on with 2 bolts. There are also two bolts at the back of the fender on the bottom of the fender. That's all I can think of at the moment that you may have missed.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-14-2006 at 11:31 AM. |
03-14-2006, 12:42 PM | #4 |
Active Member
Thanks, I know I got the two at the top and one of the bolts on the bottom, I'll have to look for another further back on the bottom. It still seems like it ain't budging though.
thanks
03-14-2006, 01:00 PM | #5 |
I'd advise removing the fuel lines and replacing them. I found lots of dry rot on the rubber parts when I did it 2 months ago.
