Old 09-27-2002, 09:22 PM   #1
neonlarry
neonlarry's Avatar
Idea for Caddy 500 swap
I was just thinking that if you wanted to put a 500 in a 4x4, instead of using the adapter for a chevy tranny, in some of the old full size jeeps, they had a buick 350 with a TH400. Does anyone know if that would work? I want to build a 500 powered 4x4 someday, and I was just wondering if i came across one of those TH400s, if it would be worth using.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-30-2002, 10:50 PM   #2
6869704X4
I think so.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 10-10-2002, 12:11 PM   #3
Duallie
Duallie's Avatar
Every time the Jeeps came with a THM400, a full-time Quadratrac transfercase was behind it. The Tcase took SPECIAL fluid, had some sort of torque converter in it, and had a chain drive. The THM400 output shaft was an odd Quadratrac-only deal, too.
Just take any everyday BOP transmission and put a 4x4 output shaft to match whatever Tcase you've got, the proper tranny-to-transfer adapter, and you're all set.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 10-10-2002, 10:35 PM   #4
srhart71
You might want to check and see if the tail area on a BOP T400 is the same as it is on the Chevy T400. I think it is. If so, you could mate it to a NP205.
srhart71 is offline   Reply With Quote
