Old 03-17-2006, 10:58 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
my truck is leaning.
My truck leans a little to the front pass side when parked on a level surface. I assume it is a worn out spring but is there anything else I need to look for?
Also if it is the spring how hard is that to replace and do I need to do both if I do one?
thanks
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 03-17-2006, 11:12 PM   #2
northcountry67
northcountry67's Avatar
Re: my truck is leaning.
It is not hard to replace the coils up front. Just take the tension off with a floor jack, remove the lower ball joint, then let the jack down. Be carefull with your brake lines. You should replace both springs. They are both 34-39 years old and if one is sagging, then when you put in a new one, the other side will look sagged.
northcountry67 is offline   Reply With Quote
Old 03-17-2006, 11:25 PM   #3
speedracer
Blank
speedracer's Avatar
check radiator support mounts too mine rotted out and fell to the passenger side
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 03-18-2006, 12:00 AM   #4
avejoe
Custer had a plan too.
avejoe's Avatar
It would be easiest to park on a slight hill.
Most fun would be to drink enough beer to adjust for the tilt.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 03-18-2006, 12:02 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
Hey I like the last suggestion
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-18-2006, 12:08 AM   #6
wibilly
wibilly's Avatar
a bigger tire on one side would do it to, lol
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-18-2006, 08:21 AM   #7
dwaite72lnghrn
Park on a flat surface and measure from the ground to the frame on both side to be sure it is the spring before you buy them. The rubber mounts might be shot or like said above the rad support rust or front cab mount/support could be gone.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
