Old 09-28-2002, 10:20 PM   #1
mikep
Used to have a truck
mikep's Avatar
auxiliary springs
Ive seen quite a few coil sprung 67 and 68 trucks in the junkyards with helper springs installed that look like half a leaf spring that runs up to the axle from the rear of the truck. In checking the build sheet of one of these trucks I see that it is a factory option. Are they any good? Worth picking a set up for $10?
No truck :-(
mikep is offline   Reply With Quote
Old 09-29-2002, 01:46 AM   #2
Hutch
Hutch's Avatar
Yes they do work well when hauling a heavy load.
$10 sounds like a deal.
You will need the mounting pads that go with the springs and to install you will need to drill some holes in your frame, if your truck was not ordered with these.
The only folk’s I have seen with these are the originally installed ones people, hauling heavy loads or the ones that have this option on their data sheet and are restoring their trucks back to the original configuration.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 09-29-2002, 02:06 AM   #3
Blue_71
Bloo
Blue_71's Avatar
there worth an extra 500 lbs each.. i like the ones on my truck
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-29-2002, 11:19 AM   #4
LeRoy
Registered truck nut
LeRoy's Avatar
I have a set off my 72 that you can have free. I've removed the spring but you'd have to remove the brackets.
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 09-29-2002, 04:42 PM   #5
slam33
slam33's Avatar
Don't forget to grap the contact plate under the axle and you need the rubber cushions, LMC has new ones. Otherwise you will get some loud slapping of the rear.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
