Old 03-20-2006, 01:44 PM   #1
Dano69c10
Dano69c10's Avatar
WTB: Auto trans conversion parts.
I need the following parts to finish a conversion from a 3spd to TH-350.
all the required linkage. (column to trans, trans to engine/carb),
TH-350 fluid dipstick and tube.
Flywheel cover.
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-20-2006, 04:23 PM   #2
70GMCer
70GMCer's Avatar
Re: WTB: Auto trans conversion parts.
Just remove your clutch and brake peddle assembly, and remove the clutch peddle. Then you have your auto peddle. That's what I did on mine swap....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-20-2006, 04:31 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And that's how they were from GM too.
Old 03-20-2006, 07:17 PM   #4
bisquik65
bisquik65's Avatar
I have a 72 auto column $65 shipped I should have the pedal setup here too..if so... $35 on it shipped
bisquik65 is offline   Reply With Quote
Old 03-20-2006, 10:45 PM   #5
67sss
67sss's Avatar
whats a THERMAC unit on #5?
67sss is offline   Reply With Quote
Old 03-22-2006, 02:58 PM   #6
Dano69c10
Dano69c10's Avatar
Bisquick65 pm sent.
I thought that the auto trans brake pedals where wider than the manual trans brake pedals.
The THERMAC unit operates the flapper door on the snout of the air cleaner to switch from heated air to outside air.
Thanx
Dano
'69 Fleet
Old 03-22-2006, 03:46 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I am so lazy...I just use a die grinder/cut off wheel and lop the clutch pedal off as close to the upper shaft as possible...never remove a part.
PICKMUP is offline   Reply With Quote
Old 03-22-2006, 03:49 PM   #8
Longhorn Man
67 - 72 trucks did not have a wide brake pedal. The automatics had the same assembly as the manual shift trucks, only with the clutch pedal removed.
Old 03-22-2006, 08:01 PM   #9
Dano69c10
Dano69c10's Avatar
Thanx Longhorn Man for the info.
Guess I can do that part of the conversion.
Dano
'69 Fleet
Old 03-26-2006, 07:28 PM   #10
bisquik65
bisquik65's Avatar
here is the column..72 auto..it has a small crack in the shift indcator...thats all that it needs..$65 includes shipping...No steering wheel..I need that for my truck
Old 03-26-2006, 09:25 PM   #11
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Just an FYI, A few years back I purchased the thermac unit from NAPA.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
