Old 03-20-2006, 12:46 AM   #1
four-eyed stang
What size rearend?
I have an 1/2 ton 81 LWB with a 305cid and TH350C. What size rearend do I have? I am looking to buy some 3:73's for pulling and need to now the housing size.
four-eyed stang is offline   Reply With Quote
Old 03-20-2006, 01:38 AM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: What size rearend?
My 80 C10 305 + TH350C has 2.56 but who knows.
There's another post referencing gear sizes, might wanna check it out, too.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 03-20-2006, 02:15 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Easiest way to tell is to count the bolts at the rear cover. This will tell you what bolt size you have. It's probably a 10 bolt but it may be a 12 bolt. You also need to pop the cover off the differential to find out what carrier size you have unless you're wanting to install a new one. Count the teeth on the ring gear and the pinion. Divide smaller number into larger number and this will give you a gear ratio on what you have in there now. You will need this to find out what carrier you have. "Usually" the lower numerical numbers like 2.56, 3.08, 3.42 have a Series 3 carrier and a larger number gear ratio have a series 4 carrier. You can resue the carrier as long as you know what size it is and get the correct gear ratio for the carrier. If you want a 3.73 and you have a series 3 carrier you may have to get a thicker set from the manufacturer but need to contact them to be safe.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-20-2006, 09:28 AM   #4
Nolowrider
Nolowrider's Avatar
79Big10 hit the nail on the head. I would say to probably have a 3.08. Not really sure what year they switched to the 10 bolt. But an 81 is around that time. Take a look on the rear end housing for a stamped number or a tag if you don't want to yank the cover off.
Nolowrider is offline   Reply With Quote
Old 03-20-2006, 06:24 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
Brandon is correct. I think a 3 series carrier will go up to 3.73 on a 10 bolt, at least it did on my 85.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-21-2006, 01:53 AM   #6
four-eyed stang
I am looking for gears on Summit. It is a ten bolt. Would it be an 8.5?
Old 03-21-2006, 02:03 AM   #7
swervin ervin
Yes, it's a 8.5.
Old 03-21-2006, 08:39 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Look at Rand'ys Ring and Pinion website for more info.
Old 03-22-2006, 12:24 AM   #9
four-eyed stang
Thanks everyone
