Old 03-22-2006, 09:59 AM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
2WD 14ff Rear....
Do any of you know if a 79 c20 14ff rear from a 2wd pickup will be the same width and if the spring perches will be in the same spot as a 4wd truck? so basically what im trying to ask is if the rear will just swap into an 86 K20. Yes, No, Maybe? And what about the rear leaf springs... are they the same? Thanks alot guys
-Scott
bbchevy is offline   Reply With Quote
Old 03-22-2006, 12:31 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: 2WD 14ff Rear....
Should be a bolt up!
Measure the width of the perches before you buy it though, just to make sure.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-22-2006, 01:57 PM   #3
bbchevy
87 Wanna Be K30
bbchevy's Avatar
even the leaf springs should bolt up?
Old 03-22-2006, 02:56 PM   #4
djohnson
Look closely at the shock mounts. I believe that there is a difference between the 2wd and 4wd.
djohnson is offline   Reply With Quote
Old 03-22-2006, 04:06 PM   #5
Russell
Professional Grade
Russell's Avatar
My 2wd and 4x4 frames had the same shocks, less length.
The 4x4 springs may be longer than the 2wd, but if you unbolt the u-bolts instead of the springs, your new diff should bolt directly to the new 4x4 springs.
Old 03-22-2006, 04:07 PM   #6
Prerunner1982
Prerunner1982's Avatar
depends if you have the 52" or 56" springs. For a 4x4 the 56"s would be best and it is a fairly easy swap to go from 52" to 56"s...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
