Old 03-25-2006, 09:46 PM   #1
trailzen
1970 body mounts
I ordered the new body mounts for the blazer today,how difficult is it to locate all the body mounts on a k5 and does anyone have any tips on making this easier.
trailzen is offline   Reply With Quote
Old 03-26-2006, 04:58 PM   #2
detroit72k5
detroit72k5's Avatar
Re: 1970 body mounts
They're easy to locate, but most or all of the heads are welded to the body, so you'll have to do some grinding or cutting. If they're poly bushings, make sure you grease them so they don't squeak. I would recommend doing one entire side, then the other side. If you have a top, make sure it's bolted on, it will help keep the body straighter in the end. Umm, you'll probably have to play with the shims a bit in the end to straighten the body back out so the doors close ok. That's the toughest part. Good luck and don't forget pics!!
detroit72k5 is offline   Reply With Quote
Old 03-27-2006, 11:13 AM   #3
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
The rear set were the toughest for me. I had to remove radiator to do the radiator support ones.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 04-01-2006, 08:28 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Gotta watch the steering shaft along with the fan and shround clearance while your jacking up the body.. Also I would watch the fuel tank lines while your jacking it up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-01-2006, 12:26 PM   #5
Jimmy72custom
Jimmy72custom's Avatar
The torque for the body mounts below the windshield is 50 ft lbs. The rest are 20 ft lbs. I have not seen any specifications on the radiator support mounts, but I heard it is 30 to 35 ft. lbs. This is for the rubber mounts, poly I don’t know.
Jimmy72custom is offline   Reply With Quote
Old 04-01-2006, 04:15 PM   #6
71jimmy
71jimmy's Avatar
Jimmy72custom, were did you find the torques specs? I replaced mine several months ago, but couldn't find any torque specs. The question has come up here several times too. At 50ft lbs., aren't you squeezing the crap out of the rubber? It didn't take much to compress the rubber.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-01-2006, 05:15 PM   #7
Jimmy72custom
I have it written in my notes. I do not remember where I got them. I do remember that it was hard to find. 50/20 ft lbs is not that much. It is easy to over tighten. My mounts still have the crap in them ;-)
