Old 03-27-2006, 10:49 PM   #1
tripleblack
short sell Ford stock
how much POR-15 does it take...
i was wondering how much POR-15 it would take to coat a SWB frame? A pint, quart or a gallon? If anyone has used this stuff i would appreciate it. Oh yeah, is there any where else to buy the stuff other than online/? thanks.
tripleblack is offline   Reply With Quote
Old 03-27-2006, 10:53 PM   #2
northcountry67
northcountry67's Avatar
Re: how much POR-15 does it take...
I'm not familiar with POR15, but I sprayed my frame with a black etch and it took about 1/2 gallon sprayable. Depending on the mixing ratio, you can get by with a quart of POR 15 if the reducer and hardener adds another quart. I did spray the top, bottom and inside the rails.
northcountry67 is offline   Reply With Quote
Old 03-27-2006, 10:56 PM   #3
chevythunder33
chevythunder33's Avatar
What ever you do use a good mask you dont want to suck that down your lungs
chevythunder33 is offline   Reply With Quote
Old 03-27-2006, 11:00 PM   #4
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=188143
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 03-27-2006, 11:17 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you are spraying it, a resporator is REQUIRED...that stuff is NASTY, if brushing it on, then good ventilation is all that's really required.
2 weeks ago i did the rear 1/2 of my longhorn... from the back of the cab on back, including leafs, axle tubes (didn't do the pumpkin, too oily) and all crossmembers. I dod 2 coats, and it took a little over a quart.
Old 03-28-2006, 10:10 AM   #6
wibilly
wibilly's Avatar
i used rustoliem and it took me aboyt a quart per coat
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-28-2006, 04:37 PM   #7
rodstored-72
chevy truck fan
rodstored-72's Avatar
tripleblack,
i used it to paint my frame. i have never sprayed before. i used right at 2 qrts. i sanded the frame to bare metal & then just started shooting. i like the way it turned out. word of caution!! for sure use a mask & what ever yo udo cover stuff up!!! it will go everywhere!!!. but it seems to stay on pretty good.
good luck!!!
rodstored-72
p.s. i also have a 2wd swb frame.
rodstored-72 is offline   Reply With Quote
Old 03-28-2006, 05:34 PM   #8
72armyswbtruck
72armyswbtruck's Avatar
Dude, I just called around and found out the POR-15 comes in Silver, Gray, Semi Gloss and Black, what color would you go with, the truck is a longhorn that is blue and white and i am thinking of keeping the paint combo.
Suggestions
BTW: Sorry to Hijack the post.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
