Old 03-29-2006, 03:19 AM   #1
Super Chevy
Super Chevy's Avatar
2wd to 4wd
hey i got a 72 c/10
and i can aquire a k5 blazer rolling chassis
can i use my 2wd steering box?
with a 4 lift up front do i still have to change the crossmember?
do i need a different tranny crossmember for the 4x4 tranny/xcase?
thanks super chevy
Super Chevy is offline   Reply With Quote
Old 03-29-2006, 05:31 AM   #2
Mudder
Mudder's Avatar
Re: 2wd to 4wd
You will need a steering gear off of a 4x4. You will also need the trans crossmember and a larger hump for your floor unless you are going to go with a body lift.
Mudder is offline   Reply With Quote
Old 03-29-2006, 10:25 AM   #3
1967k30
1967k30's Avatar
Re: 2wd to 4wd
You can use the 2wd steering box if you run crossover steering. Where are you located? I have some of the parts like a front axle,driveshafts,
t-case's,ect
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 03-29-2006, 02:10 PM   #4
mrein3
mrein3's Avatar
Re: 2wd to 4wd
Originally Posted by Super Chevy
hey i got a 72 c/10
thanks super chevy
I have a mutt truck. The chassis is a 1971 4x4 that came from the factory with a 3-speed manual tranny and a np205 transfer case.
I wanted an automatic transmission.
I ended up using a th350 and np205 out of a 1972 Blazer. The crossmember and drive shafts are the same. GM made up the differences between tranny/xfer combo lengths by varying the length of the adapter between the two pieces. What I have observed is that if you have a NP205 now, you can use any NP205 and its transmission in place of what you got.
This crossmember has NOTHING to do with the 2wd crossmember.
I'm not sure because I've never owned a 2wd, but I believe the 2wd frame is different than the 4wd.
If the frames are not different the Blazer's crossmember should work. Maybe somebody else who has done this will chime in.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-29-2006, 04:27 PM   #5
tom71
what happened to flint mi
tom71's Avatar
Re: 2wd to 4wd
ask fuel cell guy , or look under the faq section
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 03-29-2006, 11:20 PM   #6
GMCMAX
Active Member
GMCMAX's Avatar
Re: 2wd to 4wd
I swapped my 2wd to 4X4, check this thread for some Q&A:
http://67-72chevytrucks.com/vboard/s...d.php?t=188520
Max
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
