Old 03-31-2006, 10:42 PM   #1
bluec10
bluec10's Avatar
Rear Axel Conversion
I want to swap a 5 bolt rear end into my '69 GMC. Right now I have a L6 engine in the truck which will remain for a while. Eventually I'd like a hot 350 or 383. Any suggestions? What will fit?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 04-01-2006, 02:31 AM   #2
HeavyD
HeavyD's Avatar
Re: Rear Axel Conversion
How soon do you want to do this? Once the snow goes I will be parting a 71Chev if you want to buy a whole rear drum to drum. I know we don't live that close, but maybe we could work something out. I also have a complete disc front suspension of you don't already have a set up as well.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 04-01-2006, 04:22 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Why not just switch out just the spidel axels. It's not really all that difficult of a switch, however the easiest is swapping the entire axel from wheel to wheel
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-01-2006, 12:30 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Early 1970's axle's will be a direct swap for you. This changes them from 6 lug to 5 lug. About mid year in 1970 they went with the longer housing of 71 and up. They'll still fit, but will stick out farther about 3/4" on each side and I've been told the bearings will ride on a non-hardened part of the axle. Many folks have done it, but do a search and you'll find some input on this if you plan on doing it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-01-2006, 01:22 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Brad, you're mistaken. 70's were all still 5 lug, both early short axles, and longer late axles, all 6 lug.
It's getting harder to find 71-72 rearends around here. Seems lots of folks have used them all up converting stuff to five lug over the years. I'm putting a 75 model rear under my truck right now. I'm having to deal with the funny coil spring axle saddles and the panhard bar mount. Once I get it done, I'll post an FAQ article with pictures outlining it all. It's doable, but much easier and cheaper to just find a 71-72 rearend if you can.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-02-2006, 11:45 PM   #6
bluec10
bluec10's Avatar
This is exactly my problem. The 71-72 rear ends are tough to find. I've gone with front end parts from an '84 and found that the fit is almost perfect - I only had to drill 2 holes. I'm looking forward to viewing your FAQ article - thanks for making the effort. One last thing...what about axel ratios?
Present:
Past:
Old 04-03-2006, 02:50 AM   #7
Brad
Brad's Avatar
Question Re: Rear Axel Conversion
I'm confused. Perhaps we're talking apples and oranges, but I keep reading this over and over and it appears bluec10 has 6 lug axles and wants 5 lug axles. I did this swap with my 67 housing using early 70's 5 lug axles since this is a direct bolt in swap. Are we talking the same thing or am I confused regarding the request?
Old 04-03-2006, 11:37 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Originally Posted by Brad
I did this swap with my 67 housing using early 70's 5 lug axles since this is a direct bolt in swap. ?
5 lugs didnt come out until 71'
but in 70' they did have a long and short axle tubes but both were 6 lug, the later 70 is a perfect for inner swap because it was wider and doesnt cause a problem with the brake drums.
sneakysnake is offline   Reply With Quote
Old 04-03-2006, 11:40 AM   #9
Bob Moore
TexFF - IIR an added bonus to using the newer axle is that larger brakes were available. Am I correct on this?
Brad - I really thought 1/2T trucks were 6 lug through 1970. With disc brakes being introduced in 1971 they went to 5 lug. 4X4 stayed 6 lug in 1/2T.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-03-2006, 03:22 PM   #10
Brad
Brad's Avatar
Well, maybe I've forgotten what I did regarding my axles. I know I swapped in 5-lug axles in some sort of housing with the correct length axles, lol
Now I'm curious what housing I used and what I did. It's been about 5 years.
Old 04-04-2006, 06:16 AM   #11
Tx Firefighter
Bob, I do belive the later axles did all get the bigger brakes. I'll measure it when I get home next time.
