Old 04-02-2006, 03:51 PM   #1
Rokcrln
Rokcrln's Avatar
Project "Trazer" begins!
A fellow board member mkundo, just dropped off the first phase of project Trazer. Once done it will be a 2wd blazer with a truck cab grafted onto the body. For now we are starting with the frame and suspention work.
List of mods as of now,
Currie built 9" w/drum brakes.
CPP trailing arm and cross member kit.
"C" notches.
rear shock relocator kit.
new lowered springs all around.
Dropped front spindles.
New ball joints and steering links.
Then phase two will consist of a tubular spider tranny cross member, big block buick (I think) and alot of custom body mods.
So stay tuned!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-02-2006, 08:21 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Project "Trazer" begins!
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-02-2006, 08:40 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Can't wait to see more...
Just out of curiosity, what's the motivation to put a pickup cab on a blazer frame?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-02-2006, 08:56 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like your running out of room in the shop..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-02-2006, 09:07 PM   #5
Rokcrln
Rokcrln's Avatar
You can say that again! My shop is only 25x45 and inside right now is a 68 crew cab long bed, 2005 ford Bronco rock crawler, 71 rolling blazer frame, 71 rolling SWB chassie, 71 cab on Tip & Flip dolly, Extra Tip & Flip dolly, 3 welder, 1 plasma cutter, 1 full hydro tube bender (for roll cages), a 4'x4' file cabnit for magazine files, 1 table saw, 1 sliding mitter saw, 2 roll around tool chests (48'w x 70" h), one 45ton iron worker pro, wood burning stove and a beer fridge! And alot of other crap.
As far as the blazer goes what he wants is the top of a cab grafted to the blazer body to make a real short bed uni body truck/blazer. It will be different, kool and I think it is great! He is of the old school with chopped, chaneled merc's and lead sleds and this is his next street rod!
Kevin
LFD Inc.
Old 04-02-2006, 10:20 PM   #6
bouncytruck
SKINNY TIRES RULE!
I didn't realize you are doing the project for someone else.
I wish I had a shop that big...
bouncytruck 1972 K5
Old 04-02-2006, 10:23 PM   #7
72CSTC5
72CSTC5's Avatar
So you are going to basically build it like the one Boyd Coddington and Lil John Butera built a few years back?
72CSTC5 is offline   Reply With Quote
Old 04-02-2006, 11:09 PM   #8
Rokcrln
Rokcrln's Avatar
I never saw that one. Would you have a link or some pics. I am still getting my head into the project. I have a few months before the body comes down for mods. Right now it is just frame and suspention work. Then once I finish a few other customer projects and get my 71 SWB a few more steps forward I should have the shop cleared out for the task. Should be a fun build!
Kevin
LFD Inc.
Old 04-02-2006, 11:34 PM   #9
bouncytruck
SKINNY TIRES RULE!
Images won't link -
http://cars.buzztrader.com/showimage...950_8649_1.jpg
bouncytruck 1972 K5
Old 04-03-2006, 12:14 AM   #10
Rokcrln
Rokcrln's Avatar
I guess this is along the idea of what he wants. We have not gotten real in depth into it yet. Once the frame is done I will go check out the body and his donor cab and go from their. We will do a few sketches and through some ideas around and see what he comes up with.
I had to save it and resize a few times but..
Kevin
LFD Inc.
Old 04-03-2006, 10:43 AM   #11
smbrouss70
smbrouss70's Avatar
Kevin, There's a few more pics in this article... http://www.truckinweb.com/brandpages...0207tr_custom/
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-06-2006, 09:44 PM   #12
Rokcrln
Rokcrln's Avatar
Well I was able to get a few hours in tonight. After 28 rivits to remove I must say I love my plasma cuter! Now that the rear is out I will de-grease what little their is and pull the front suspention and get to work on a re-build. And don't even ask if all the stock rear(12bolt 3.08) parts are for sale or trade because this is not the right forum for that. If you have any problems with that just PM me with your complaint
Kevin
LFD Inc.
Old 04-06-2006, 10:28 PM   #13
smbrouss70
smbrouss70's Avatar
So what kind of rear susp. is going in?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 04-06-2006, 10:38 PM   #14
Rokcrln
Rokcrln's Avatar
It is getting the full CPP kit with the new lowered cross member that has the pinion angel adjusted for a 4" drop. Then their tubular trailing arms, 1.5" lowering blocks, 4" lower springs, adjustable full length panard bar, "C" notches and new shocks. Then it he has a currie set up 9" with new axels, drums and inners. Front is getting 2.5" drop spindles, lower springs, new steering parts, shocks and maybe rebuilt A arms and a power steering box. Then posibly a Por15 frame job.
Kevin
LFD Inc.
Old 04-08-2006, 04:44 PM   #15
Rokcrln
Rokcrln's Avatar
Well the frame is stripped clean, de-greased and preped ready for POR15. Now once it dries it will go into the shop to get C notched and a few other things then paint time and re-assembly.
Kevin
LFD Inc.
Old 04-08-2006, 05:58 PM   #16
72armyswbtruck
72armyswbtruck's Avatar
Lookin good, I still say that you do wonderful work and If I had the money my truck and project would go directly to you
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-08-2006, 08:49 PM   #17
Rokcrln
Rokcrln's Avatar
Thank you! Who know maybe some day I may have a shop up by you?
Kevin
LFD Inc.
Old 04-09-2006, 12:23 AM   #18
Rokcrln
Rokcrln's Avatar
C-notch time! Well first off I want to say the kit is very well made and is from CPP. What I do not like about it is the directions, they leave something to be desired. First thing you want to do is remove the rivits in ther bottom of the coil spring plate(2 per side) and then remove 2 more infront of the panard mount. Next hold up the Notch and aling the front of the side plate with the rear edge of teh oval hole in the frame. Once this is aligned then mark the frame for cutting. Cut the notch tight at first and trim it little by little to fit just right making sure the oval hole lines up as shown. You will also need to trim off a bit of the coil spring mounting plate on the out side of the frame so your notch sits tight to the side of the frame rail. Once this is done, clamp the plate to the frame and smack it with a hammer to ensurte it is seated all the way. Install the bolts that you can and snug then up but do not tighten yet. Now mark all the rest of your holes that need drilling and center punch then drill out to 7/16" (for CPP's kit). After all holes are drilled remove the plates and paint any part that will be clamped together as you wil not be able to get to this after they are installed. Now tighten the bolts (note one bolt had to be cut because it hit another bolt next to the panard mount) in the order givin in the directions. Now paint everything and install the bump stops in the top of the notch's. We will be welding ours in some spots (per the customers directions) for added strenght and painting the entire frame with POR15. Well that is as far as I got tonight. I will Tig it up tomarrow and move on to the front suspention.
Kevin
LFD Inc.
Old 04-09-2006, 12:25 AM   #19
Rokcrln
Rokcrln's Avatar
A few more.
Old 04-09-2006, 03:34 PM   #20
Rokcrln
Rokcrln's Avatar
Try time! Welded in the notch's and preped the frame and went to town. I just love how POR15 flows and melts together. Now it is in my heated redneck paint booth to try (Large garage with wood burner). I will start the front suspention rebuild later today.
Kevin
LFD inc.
Old 04-09-2006, 06:57 PM   #21
krue
Designated A-hole!
krue's Avatar
Looks good!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-09-2006, 11:20 PM   #22
Rokcrln
Rokcrln's Avatar
I will prep the rest of the parts in the next day or so and start putting it all back together. I used my 45ton iron worker pro (punch,break and shear) to pop out the lower ball joints. That came out like they were not even their.
Kevin
LFD Inc.
Old 04-10-2006, 12:23 PM   #23
Yukon Jack
Yukon Jack's Avatar
Those are some beautiful welds!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-11-2006, 12:03 PM   #24
70rs/ss
70rs/ss's Avatar
I did a bunch of those rivets, the hard way!! I used my cutoff wheel and knocked the heads off then had to air chisel em out. I had rust in my plates (NC by way KY!) I thought the world would end before I got all of them out (same plates as shown in your pict). I need a TIG!! I am certified, but they are spendy for home use, great work!!
70rs/ss is offline   Reply With Quote
Old 04-12-2006, 06:25 PM   #25
Rokcrln
Rokcrln's Avatar
Just about done! I will get the rest of the part on Thursday when the owner stops by. I am just missing the new tubular trailing arms, rear 9" backing plates, front spindles and front springs.
Kevin
LFD Inc.
