Old 04-03-2006, 04:06 PM   #1
farside847
farside847's Avatar
Rear main seal leak
Well, I am told that my leak is from my oil pan, and my rear main seal. So, like a good little weekend warrior I opened up my chevy manual to see how to replace this thing. For some reason I thought you had to back the tranny off to do it, but my manual only says I need to take off the oil pan, then take off the seal cap. Is this right? It seems too easy, but then again the illistrations are not too good on this procedure.
Overall, how hard do you think this would be to do? I know I will need to drain all the oil out, take off the pan, take off the cap, replace the seal, and put the pan back on with a new pan seal and put in new oil. Am I missing anything? Will I need any special tools to get the old seal off and put the new one on?
Thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 04-03-2006, 04:41 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Rear main seal leak
Nope, you have it covered. It is not hard, just a PITA to have to drop the pan and all to replace a $5 part. Good luck.
70rs/ss is offline   Reply With Quote
Old 04-03-2006, 06:21 PM   #3
farside847
farside847's Avatar
Cool. My manual also says to use sealant around where the two bolts go in on the cap. Do you guys use sealant too?
Old 04-03-2006, 06:38 PM   #4
ozzyracing
Don't forget to get the torque specs for the cap bolts. Hate to have one of those get loose.
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 04-03-2006, 07:00 PM   #5
cdowns
cdowns's Avatar
get yourself a one piece pan gasket from FELPRO it's well worth the extra money
Old 04-03-2006, 07:45 PM   #6
Ole Blue 68
Ole Blue 68's Avatar
Yes, just don't get any on the seal itself or it could effect its ability to seal properly.
Also, I found the diagrams from this page helpful.
http://www.autozone.com/servlet/UiBr...3d800514cd.jsp
Ole Blue 68 is offline   Reply With Quote
Old 04-03-2006, 09:34 PM   #7
jcfoote60
Active Member
jcfoote60's Avatar
Cdowns has it right, spend the extra bucks on a Felpro one-piece. The other thing is if you do go for the one piece do not use any sealant, it's designed to eliminate the need for that mess. You can also take your pan back off and reuse the same one piece gasket. It's worth the dough believe me...
jcfoote60 is offline   Reply With Quote
Old 04-03-2006, 09:41 PM   #8
jcfoote60
Active Member
jcfoote60's Avatar
Oh and one more thing, make sure you know EXACTLY what your engine is and what year. You can find the engine code on the rear of your engine, drivers side below the cylinder head there is a flat casting. the number is there probably hiding under some grease. Once you get the number go here to find out all you need to know about your engine so you don't get the wrong gasket.
http://www.nastyz28.com/sbchevy/sblock.html
