Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 04-03-2006, 11:05 PM   #201
rage'nrat638
rage'nrat638's Avatar
Re: New Project truck!!
more pictures....
rage'nrat638 is offline   Reply With Quote
Old 04-03-2006, 11:15 PM   #202
Mike76251
How 'bout just one pic of that engine bay with the 638!!!!
Mike76251 is offline   Reply With Quote
Old 04-05-2006, 11:33 PM   #203
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Taking the truck FRIDAY to get the engine bay painted. Made a few panels for the fenders to cover up the ugly. Pics will follow when complete.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 04-30-2006, 04:52 PM   #204
phantom dually
Well the truck is still at the paint shop going on 3 weeks now. Not much has been done except the filler and a a little sealer added. Good thing Im not in a huge hurry!!
Old 05-09-2006, 05:24 PM   #205
phantom dually
No good updates yet. Truck is Still at the paint shop and no work has been done. Painter swears that it will be done this week though. It has been there a month today. I really should learn how to paint. I bought a few more pieces for the motor and should be ready to drop it in when and if I ever get it back. Sorry for the rant!!
Old 05-10-2006, 01:40 AM   #206
96extcab
Ok, granted I never post. Hang in there with the waiting man. Sent mine off for cab corners and a dent repair in February of '05, told me 10 days. Almost April when I got it back. If you're painter is cool like mine was, he'll give you a break on the price.
1996 Chevy C1500 ext. cab short bed 350, complete rockford/infinity stereo, headlight flashers, true duals, euro clears up front, FIPK gen2, more is definately on the way.....
96extcab is offline   Reply With Quote
Old 05-10-2006, 04:28 AM   #207
97silv5.7
MooMoo
97silv5.7's Avatar
looking forward to seeing it finished
'97 ext 4x4 3" body lift and 7'6" Fisher MM2
'04 Polaris 700 twin EFI **sold 2-1-07**
'07 Polaris 800 twin EFI Stealth Limited Edition
Support the Board! Or deal with me foo!
Its all fun and games till you find out shes 16.
97silv5.7 is offline   Reply With Quote
Old 05-11-2006, 07:28 PM   #208
phantom dually
Me too!! Wife is going to Florida in July. Staying home and takin the week off. Hoping to get the motor in no later than that week. Maybe not runnin but in!!
Old 05-12-2006, 06:54 PM   #209
phantom dually
Ok guys I got the truck back!! These pics are just a few minutes after I got it into the garage. I know alot of people will say why didnt you shave the whole firewall. Well I dont really want to go thru that much work. I wanted to clean up the firewall and remove the items that I will not be using. Wipers heat AC etc etc. As most of you know you are never done so I could have went on and on. My goal here is to build a clean weekend driver. While I may go to a few shows here and there my main intent is to have fun with it. Anyhow here are the pics. I had the firewall painted and the inside of the fenders. The painter also got the core support and up to the windsheild. I have the inner fenders and the brake booster that have been painted to mount also. I made some template of the inside of the fenders and had those painted too. Enjoy!!
Old 05-14-2006, 12:57 PM   #210
Crank
Crank's Avatar
Your truck is really coming along. I was gonna come check it out when it got done, but the Marine Corps. had other plans, they didnt let me stay in KY. But I'm sure I'll see it at a show or two once I get some time to come home and crap. Cant wait to see the thing with the BB and that TKO in there. Need to buy you some real ****ty 15x12's and have some cheap tires mounted for the burnout pics that you absolutely must show.
Brandon
Crank is offline   Reply With Quote
Old 05-29-2006, 12:18 AM   #211
phantom dually
Made a little more progress today. Got the rest of the frame cleaned up and primed/painted. Cleaned up under the cab also and used Duplicolor spray in bedliner like I did on the underside of the bed. Im pretty happy with the results. I got the motor mount inserts from Energy suspension to get bolted back in next. If anyone has done mounts on these trucks IT SUX!! Anyhow Im going to get a few odds and ends for the motor done before I drop it in. I got the intake bolted down today and pressed the balancer on.
Old 06-04-2006, 11:40 AM   #212
phantom dually
I got a little progress going last night. Sat the motor into place and bolted down. Didnt take to long at all. Going to start bolting up the flywheel and Tko tranny as soon as i order a few small parts from summit.
Old 06-10-2006, 05:36 PM   #213
phantom dually
Ok got the McLeod twin disc clutch put in. Also bolted up the Bellhousing as well. Cut a hole into the floor for the shifter. McLeod forgot to send my throwout bearing with the hydraulic assembly so Im at a stand still until then. Went to put my timing tab on and found that on a big block the lower bolt of the cover is used to mount the tab. So off the balancer comes to fit the tab. Got the tab mounted and remounted the balancer. Guess what the balancer hits the tab. Now I got the balancer off a again and have to take about a 3/16" off the back flat surface where it bolts to the chain cover. After I get that done I can put the serpentine setup on.
Old 06-13-2006, 12:26 AM   #214
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by phantom dually
... I made some template of the inside of the fenders and had those painted too. Enjoy!!
Does that meen you are putting filler panels in there too? That will make a huge difference if you cover up some of those holes.
Engine bay is looking really nice...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-13-2006, 06:37 PM   #215
phantom dually
Exactly. The panel starts at the front of the inner fender and covers every hole to the rear by the firewall.
Old 06-13-2006, 11:33 PM   #216
N2TRUX
Happy to be here
N2TRUX's Avatar
That's what we did on my 77. It really helps smooth things out...
Articles-
"Refining Sierra"
Old 07-28-2006, 12:03 PM   #217
97silv5.7
MooMoo
97silv5.7's Avatar
any updates???
Old 07-30-2006, 05:54 PM   #218
phantom dually
Yes I have a few. I will go shoot a few pics here in a little. Meanwhile I am test fitting the gauges. I want to get some honest opinions on it first. I have a few thoughts about it but will keep them to myself and see if you guys have any.
Old 07-30-2006, 05:56 PM   #219
smbrouss70
smbrouss70's Avatar
I like it, but I might paint the panel a satin black, just to make the gauges "pop" out at you a little more.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-30-2006, 06:03 PM   #220
phantom dually
Yeah I originally thought of doing that. The reason I went with the polished is that the engine is Black with polished pieces. I thought the polished panel would give it some pop.
Old 08-01-2006, 01:26 AM   #221
97silv5.7
MooMoo
97silv5.7's Avatar
I think the polished look looks much better than a black look, I think it makes the cluster stand out more
Old 08-01-2006, 05:33 AM   #222
It does look good. I think either way, polished or black would have looked good.
Old 08-01-2006, 08:52 AM   #223
smbrouss70
smbrouss70's Avatar
What were your thoughts on it, Phantom?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 08-04-2006, 01:36 PM   #224
kdailey4315
I think the guages look great. Did you have to completely customize the dash or can you buy complete sets like the ones theysell at covanclassics.com?
kdailey4315 is offline   Reply With Quote
Old 08-05-2006, 12:49 AM   #225
phantom dually
My thought is that it may be too much. The gauges on the left look to set up higher though on the plate they are actually dead even. One thing I noticed was the left side of the bezel itself is rounded in the top left corner and the right side of it is more squared. Being that the two sides are diffrent it sticks out to me. I guess i will try black background and go from there.
