10-01-2002, 11:08 AM | #1 |
Question About Taking Apart a Bed
I am going to put a metal floor in my truck to replace the wood one, and I bought a old bed that I am taking apart. The one part I can't figure out is how to get the 4 "screws" out that hold the upper front corners of the bed together. They are stuck too tight to remove with a screwdriver, but I don't want to drill them out because they go thorough the nut that is welded to the front panel (which I also need to use) any ideas?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
10-01-2002, 01:21 PM | #2 |
English Chevy Owner
Get an impact driver, takes a screwdriver bit one end and you hit the other end hard with a BFH and it usually shocks it free. Available from all good tool suppliers (I sound like a TV commercial!)
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
10-01-2002, 02:32 PM | #3 |
Ok, I will have to try that again. I tried once, and I could not get them to even move. Any other ideas if that won't work?
10-01-2002, 04:12 PM | #4 |
Mine were seized, an impact wrench didn't do it, finally ground them off. Good luck
71 GMC 1500 LWB |
10-01-2002, 04:26 PM | #5 |
Yea, that kinda sound like the old bed that I have. How did you get the other part of the bolt out?
