Old 04-08-2006, 10:25 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Charging System Not Charging
Fired up the old camper special for the first time this spring(been sleeping in the barn all winter) when i hooked up the battery it sparked even though there was nothing turned on in the truck (key off battery drain???) and it also was not charging after i started the engine. The PO converted to the new style alternator, so mabye he didn't have it wired up right? Any suggestions?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-08-2006, 10:38 PM   #2
jhow66
jhow66's Avatar
Re: Charging System Not Charging
Check here:
http://www.madelectrical.com/index.shtml
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-08-2006, 11:03 PM   #3
Mechdawg
Mechdawg's Avatar
If the PO left the voltage regulator hooked up and its gone bad I think it can cause the battery to drain you might wanna check that.
Mechdawg is offline   Reply With Quote
Old 04-08-2006, 11:28 PM   #4
rkarr
rkarr's Avatar
You know... If there was a credit card attached to it, i'm sure my ex could make it charge....
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 04-09-2006, 01:03 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Are you certain there wasn't a dome light or headlight switch on?
Check out this site for a good reference on the alternator conversion.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-09-2006, 01:06 PM   #6
Blue85
Oilfield Trash
Blue85's Avatar
I think it is the regulator, it "clicks" when i hook the battery up, I also spotted a bunch of bare wires in the underhood harness, probably just gonna swap out the whole harness with another one i have that i know works.
87 Chev 3+3 4x4
