Old 04-08-2006, 10:49 PM   #1
Russell
Professional Grade
Russell's Avatar
67-72 Chevy accessory bracketry pics needed!
Hey guys!
I'm wanting to convert my truck from Serpentine back to V-belts. But, I need to move my alternator over to the driver's side of the truck, and I need the bracket to bolt only to the engine's heads / water pump etc, and not to the intake manifold in any way.
I think that 67-72 brackets fit the bill, so I'd like to see a few pictures of your guy's belt setups, and if it'll work like I hope it will, I'll go and find a 67-72 donor vehicle for brackets
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-09-2006, 05:26 AM   #2
JimKshortstep4x4
Re: 67-72 Chevy accessory bracketry pics needed!
Here you go!
Jim
Old 04-09-2006, 01:08 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
man that looks pretty
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-09-2006, 03:37 PM   #4
Russell
Professional Grade
Russell's Avatar
Looks exactly like what I need!
Anyone have anything closer up? I need to see how it all bolts together
Old 04-09-2006, 09:57 PM   #5
Russell
Professional Grade
Russell's Avatar
TTT -- The more pics the better!
Lets see your shiny new engines, and your old greaseballs
Old 04-10-2006, 11:59 AM   #6
Yukon Jack
Yukon Jack's Avatar
Here is a pic of the alternator bracket and power steering bracket on my 70 K5, however, this is not the correct motor, it is a 400sb and the heads were drilled to accept the alternator bracket (the heads turned out to be early 60's 327 heads - I do think this is the correct brackets though.
Here is another shot of the alternator bracket.
Here is the alternator bracket that was on my 69's 307.
And here is a pic of the power steering bracket on the Blazer's 400sb - it attaches to an engine mount bolt and on the front of the block there are two bolts.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-29-2006, 10:47 AM   #7
jpkerley
Active Member
are you interested in selling your serpentine setup??
jpkerley is offline   Reply With Quote
Old 06-29-2006, 06:14 PM   #8
Russell
Professional Grade
Russell's Avatar
For those who are PMing me -- I've got a setup from a Camaro on my truck now So, I am good to go!
Thanks anyways!
Old 06-29-2006, 06:37 PM   #9
70chevyfreak
70chevyfreak's Avatar
Check this thread, he has the brackets that you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=203995
70chevyfreak is offline   Reply With Quote
