Old 04-11-2006, 05:09 PM   #1
RunTMCfan
RunTMCfan's Avatar
Had my Tranny and Tcase rebuilt
Been gone for a while and thought I would post some updates on my Blazer project. 72' CST
This thing leaked from anywhere it had fluids. Especially the valve covers, tranny and t-case. This created a 1/2"-1" layer of asphalt and oil/tranny fluid on the undercarriage. The original owner was a hack. So I set out to clean this thing up before I did anything else (paint and trim so far). Reliability is key to me. You know that saying "chrome won't get you home."
You would be amazed at how much oil can flow from bad valve cover gaskets. The previouse owner over tightened the hand screws and bent the covers, thus created a bad seal.
I spent hours pressure washing and cleaning so I could remove the both the tranny and t-case. I forgot how much work it is to remove those suckers. It had been ten years since I did the same to my now sold 70'. I had the tranny redone do to seeing large deposits of what I determined to be clutch material debree in the pan when I swapped out the filter in hopes of fixing the problems (cheapest fix first right). Oh yeah, and a leaky front pump seal. The t-case really doesn't like to be 100% full of ATF and that caused it to leak from every seal. So I figured to get it resealed. When they opened up the t-case they found wear typical of an unserviced 30 year old 205.
So I had that done too.
Here are some photos of the tcase after the bottom of if was pressure washed. Keep in mind the gunk you see on top was not the worst of it. The gunk on the bottom was crazy.
WOW! For a rookie I got the photos up!
Both the Tcase and Tranny are rebuilt and back in. Now I need to put on some new shocks and stabilizer. This thing is pretty loose over 55mph.
Thanks for looking,
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 04-11-2006, 05:16 PM   #2
Scrubby
Check out GMTrucks.org
Re: Had my Tranny and Tcase rebuilt
No pics of them rebuilt?
Sounds like some good progress.
Scrubby is offline   Reply With Quote
Old 04-11-2006, 05:22 PM   #3
RunTMCfan
RunTMCfan's Avatar
I'll see what I can do about that. I even painted the crossmember for good measure.
Rob
"RunTMCfan"
Old 04-11-2006, 05:39 PM   #4
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
That's the most time consuming part of doing anything with the drive train...........cleaning.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 04-11-2006, 06:46 PM   #5
Medicanman71
Medicanman71's Avatar
"RunTMCfan"
been there, done that.... oil was coming out as fast as i was putting it in..
Medicanman71 is offline   Reply With Quote
Old 04-11-2006, 07:30 PM   #6
vtblazer
vtblazer's Avatar
Sounds about right, most PO's weren't real 'clued' in.
Check your steering parts/pieces for wear to help that highway driving issue.
vtblazer is offline   Reply With Quote
Old 04-11-2006, 09:21 PM   #7
krue
Designated A-hole!
krue's Avatar
My stuff resembles that! I gotta get a pressure washer and get mine clean.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-12-2006, 10:14 AM   #8
Yukon Jack
Yukon Jack's Avatar
Don't just think of it as gunk, think of it as rust preventer - the bottom of my K20's floor was so covered, I think that helped keep it from rusting
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-12-2006, 10:30 AM   #9
makovai
makovai's Avatar
I'm right there with you.....lost the forward pump in my TH350 last week. I'm pulling tranny and transfer case tonight.
Anybody wants to come by and help i have lots of tools, and some really big hammers, oh and a sawzall
Oh BTW , i noticed someone filled my Tcase to the top as well. what is it with peeps, if aint broke, fix it till it is.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 04-12-2006, 03:14 PM   #10
70rs/ss
70rs/ss's Avatar
Oh BTW , i noticed someone filled my Tcase to the top as well. what is it with peeps, if aint broke, fix it till it is.[/QUOTE]
You're kidding, right? They fill up with tranny fluid because a seal between the trans and transfer goes bad and the tranny fluid pours into the case, but you knew that, right?
70rs/ss is offline   Reply With Quote
Old 04-13-2006, 05:37 PM   #11
RunTMCfan
RunTMCfan's Avatar
I was going to post the "after" photos all nice and clean. Spent all day yesterday fishing at a lake that just opened here in San Diego (yes they close the lakes here). Now I'm dehyrated and tired. Too many beers and Margi's.
I will get photos soon.
Rob
"RunTMCfan"
