Old 04-12-2006, 02:51 AM   #1
cb
suspension for bodydrop
i see most people have gone to tubular control arms in the front, is there any decent resonably priced kit for these trucks that are worth using. also i want to lay body but also want to drive this truck at a somewhat reasonable height, do i also do a spindle, if so what is a good size?
Craig Berland
cb is offline   Reply With Quote
Old 04-12-2006, 03:44 AM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: suspension for bodydrop
The cost depends on your budget and fab skills. Get your air ride parts from ***************** Art arms cost way too much! The lower you go is going to affect the lift you are going to get. Body is easy Z the frame 3" and use shorter body mounts when bagged, also if you dont go with tube arms it helps if you dont use lower cups. Spindles for big rims..
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 04-12-2006, 10:28 AM   #3
cb
hey thanks for that link. im building this truck is on a pretty tight budget concidering what i want to with it. has anyone made their own tubular control arms by hacking the stock uppers to salvage the ball joints and ball joint mounts? looks like most of the aftermarket tubulars are about 1" round, does anyone know what thinkness of side wall to use... (.120 seems like it would be stong enough...?)
Craig Berland
Old 04-12-2006, 03:18 PM   #4
valleycustom
I make control arms. I use 1 1/8" DOM .250 wall. 1" .120 wouldn't be enough. You need to make a good jig so you get the arms correct or things could get ugly. If your wanting to make arms just make everything. It's not worth chopping parts off of the factory arms and trying to make them work.
Later
Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 04-12-2006, 06:51 PM   #5
XXL
Seņor Member
XXL's Avatar
What's the connection? Spindles for 2.5" (or 3", depending on brand) drop... big rims or not. And regardless of rim size, tire OD is going to define overall vehicle height (along with suspension components), so if you want, say a 29" tire, you've got to do x, y, and z to get the truck to a particular height. That tire can be on a 22" rim or a 15.
XXL is offline   Reply With Quote
Old 04-12-2006, 09:46 PM   #6
camaro__thunder
With my new lowers I have to run bigger rims, just like on the import trucks. If I run a 15 they will rub when I'm rolling low.
My Project 69 SWB
Old 04-12-2006, 09:49 PM   #7
Rokcrln
Rokcrln's Avatar
Because wit 15" rims and drop spindles you run into the problem of your lower arm hitting the rim. So larger rims get rid of this problem is were I think he was going with this. And yes it does not always hit and their are alot of diferent things to take into account for proper ride height and laying frame but you have to start some where.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-12-2006, 09:51 PM   #8
camaro__thunder
thanks rok! close posts...
My Project 69 SWB
Old 04-12-2006, 10:26 PM   #9
XXL
Seņor Member
XXL's Avatar
You've described your scenarios well, but neither have anything to do with the piece I originally quoted and responded to...
The assertion here is that if you use big rims, you should go with spindles. I'm saying there is no such relationship inherent. You've both made a (legitimate) argument for "for spindles, big rims."
Old 04-12-2006, 11:51 PM   #10
camaro__thunder
I agree, overall tire height is a main factor.
My Project 69 SWB
Old 04-13-2006, 01:16 PM   #11
XXL
Seņor Member
XXL's Avatar
So what does this have to do with seeing more pics of your truck??!!
Old 04-14-2006, 12:56 AM   #12
revn67
revn67's Avatar
if ya wanna make your own spindles then you can get the balljoint plates at AA.....it is a race car catalog with all sorts of tabs and things for suspension......www.aa-mfg.com get their free catalog, it came in like 4 days when i requested one
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 04-16-2006, 01:21 AM   #13
camaro__thunder
NOT TO STEAL THE THREAD BUT SOMEBODY STOP ME! We are going to scrap the trailing arms and 2 link it now... I wanna drive it
My Project 69 SWB
