04-16-2006, 09:02 AM | #1 |
astro van door seals work GREAT!
After hearing about using door seals from S-10 blazers I went to look for some yesturday. I couldn't find any that were in good shape but while poping my head in the sliding door of an Asto mini van I noticed the weather stipping on the door jam. It was in great shape and really long. So I yanked it out ( no tools required, but I did kind of bend the krimp part of it ) They charged me about $5 for it so hey no big deal if it's no good. When I got it home and started re-bending back into shape the pinch-grip part I felt 2 "thick" parts on the gasket side. "Rats" I said to myself,, "this might be too thick for the door to close ". So I cut the seal at one of the thick parts ( side cutters work perfect) and found a piece of foam inside about 1/2" diamater by about 8" long. Good part was it pulled right out. Now , how the hell do I get the other piece out without cutting the seal? Well, there were tiny little holes in the gasket by the other "thick part" . It was amazingly easy to spread the little holes enough to get a hold on the inner piece of foam and it pulled right out. So I installed the seal on my truck and closed the door ( I'd heard with the other seals doors were hard to close due to the thicker seals ) The door closed great, the seals looked great and I was a happy guy. With the "thick part" still inside I doubt if it would have closed without a real hard slam, if at all. So keep your eyes open for minivans if you need new door seals. I think the location of the seals on the body of the minivan helps them avoid wear and tear. They are plenty long ( about 3' extra ), cheap, and they work good. Happy JunkYarding everybody
I got a bench seat baby, you don't have to sit over there. |
04-16-2006, 06:35 PM | #2 |
Designated A-hole!
Re: astro van door seals work GREAT!
Nice tip.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-16-2006, 07:00 PM | #3 |
cool!
04-17-2006, 01:26 AM | #4 |
Still drivin' a Rat Rod
Sounds like I need to go to hte salvage,or my Uncles,there's one sitting in his driveway
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
04-17-2006, 05:58 AM | #5 |
Purple, Did you use the weatherstripping from the front doors or the sliding door.
04-17-2006, 01:05 PM | #6 |
Also, what year? Or are they all pretty much the same?
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
04-17-2006, 01:25 PM | #7 |
How about going down the road? Are they tight enough so there is no wind noise? I need to go junkyarding soon, I was thinking of getting new seals and seatbelts out of an s10...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-17-2006, 11:49 PM | #8 |
I used the seal from the sliding door. ( so, you gotta find 2 vans ) Not sure about the year, but they look pretty much the same for quite a few years. I have an 89 for a grocery getter/ kid hauler, we have fairly new one at work and they look similar. Not sure about the van front doors,( I never looked) I haven't driven it yet, I'm still painting the interior, but they seem to seal real good, no daylight like before ( the old seals were about 80% missing). It does take a little more of a slam to close the door than before, but not enough to consider adjusting anything. By Saturday I hope to take it for a spin and report back. hope this helps
04-18-2006, 02:27 AM | #9 |
Did removing the *thick* part leave cut open rubber seals?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
04-20-2006, 12:20 AM | #10 |
I have not installed mine yet but--- I got the seal from the ChevyLumina/PontiacTransport front doors. Doesn't seem to have a hard spot at corner like some of the S10 seals. Also is longer than necessary to fit the truck. Cut to fit and hide the joint under the stainless door jamb sill.
I have not looked at the Astro vans but will do so shortly.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
04-20-2006, 12:47 AM | #11 |
Just hang'n around
I better not see any of you scavengers in my driveway tonight.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
04-21-2006, 07:35 PM | #12 |
4X4.. removing the piece of foam from inside the seal didn't require cutting. The seals are about 3' too long for our trucks. So I cut it at one of the thicker parts ( you can't see it, but you can feel it, the seal part is hollow, but in 2 places there's these stiffeners inside ) and pulled out the plug. For the other thick part I just spread open 1 of the little holes that are in the seal. They're tiny hardly bigger than a pencil lead, but you can spread them apart. I just stuck a nail in to get a pice of the foam started and grabbed it with needle nose plyers and pulled the pice out. Also when I first posted I didn't have the steel door sills in place. Since installing them it's a little harder to close the door, not sure why that is. Perhaps a little adjusting may be required after all.
