Old 04-16-2006, 09:29 AM   #1
makovai
makovai's Avatar
rear crossmember
I pulled the transfer case and tranny yesturday but i cant get the rear crossmember out of the frame. Is this normal? Can the rear crossmember be taken out without drilling out the rivets?
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 04-16-2006, 09:50 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: rear crossmember
Mine was bolted in??? You are talking about the tranny/t-case crossmember right..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-16-2006, 10:24 AM   #3
makovai
makovai's Avatar
exactly.....mine is bolted in too. But it will only slide inside the frame. I cant get it out of the frame because its made of 3 pieces and the 2 drop pieces are riveted to the main crossmember.
www.fast77.com
1996 Z71 w/ 35's
Old 04-16-2006, 10:30 AM   #4
Rokcrln
Rokcrln's Avatar
If I am thinking of the right part you should just have to twist it (one end forward and one end backwards) and it should come out. Also their is a small area of the lower frame that is rolled down abit and one end should side out in that location. Hope this helps I am a 2wd guy.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-16-2006, 10:47 AM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sounds kinda like you have the SKID PLATE w/ 2 crossmembers, if so
YES just torch the lower 8 rivets and replace w/ bolts, look like this?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-16-2006, 11:13 AM   #6
makovai
makovai's Avatar
i added a pic. the cross member slides like a railing system. its so tight in here i cant cock it to get it out. Is this normal?
www.fast77.com
1996 Z71 w/ 35's
Old 04-16-2006, 11:32 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
What I did was beat it out and then I rounded the corners before I put it back in it seemed to go in easier but yes it was a tight fit..
MEMBER #6377
Project "7DEUCE"
Old 04-16-2006, 03:31 PM   #8
ericguy320
I pulled mune out yesterday, just had to take the bolts out and pull the drivers side to the back and it came out. it was a close fit but i didnt have to use a hammer
http://community.webshots.com/user/ericguy320
1972 Chevy C10 SOLD
1972 k5 blazer cst 350, sm465, rust
1993 gmc Typhoon for sale $13,900 obo
1980 Ironhead Sportster
ericguy320 is offline   Reply With Quote
Old 04-16-2006, 11:20 PM   #9
makovai
makovai's Avatar
hmmm....maybe i'm just being stupid......i'll take another crack at it tommorow.
thanks
www.fast77.com
1996 Z71 w/ 35's
