Old 04-16-2006, 12:17 PM   #1
CG
BlahBlahBlah
redrilling 6 lug axels for 5 lug
is this a job any machine shop can do? what sort of money would you expect to be charged for this?
Old 04-16-2006, 12:49 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: redrilling 6 lug axels for 5 lug
Could get pretty expensive, I say just buy new 5 bolt axels
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-16-2006, 01:20 PM   #3
Deuce
Deuce's Avatar
I think early classics makes a set of conversion axles for the 67-70 diff.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-16-2006, 01:34 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dennis Brooks did this. Search under his name and you should turn up his posts. He always has good tech reading.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-16-2006, 01:47 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=163480
try this???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-16-2006, 01:50 PM   #6
Tx Firefighter
That's the thread I was remembering. The guy is a rock star.
Old 04-16-2006, 02:30 PM   #7
BowTieMan
BowTieMan's Avatar
When I worked at a drive shaft shop I asked the machinist that did some work for us about doing this and he said he wouldn't recammend it because welding hardened metal will weaken it and it is just as easy to get a set of 5 lug axles.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 04-16-2006, 02:33 PM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Buy new axles with straight flanges, straight shafts, clean smooth bearing surfaces and avoid the possible trouble with welding, grinding, welding, drilling and used axles.
PICKMUP is offline   Reply With Quote
Old 04-16-2006, 05:00 PM   #9
CG
BlahBlahBlah
i saw you could get em from a bunch of the parts people i just wasnt sure what was involved in redrilling. it looks like you can save money if you are able to do alot of the work yourself...which i cant =( thanks for the thoughts and the thread. eye opening read.
Old 04-16-2006, 05:53 PM   #10
69face
69face's Avatar
what type of rear end do you have? If you have a ten bolt, I think you should just get another rear end. I see guys saying that it cost them a minimum of $260 to complete the job. You may be able to find a complete rear end with 5 lugs for that price or a little more if it has posi, gears, etc., but you want posi, gears, etc. anyways. I was thinking about drilling mine also, but after reading Dennis's article I think i'll just try and find another rear end. Good Luck!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 04-16-2006, 07:31 PM   #11
Tx Firefighter
It's easy to put a 5 lug rearend out of a leaf spring 73-87 into an earlier coil spring truck. I just went through that yesterday. As long as you buy the new saddles, it's easy. I was buying a new track bar anyway.
Old 04-16-2006, 07:43 PM   #12
dennislbrooks
dennislbrooks's Avatar
After doing 2 pair I would not weld up the old holes with the exception of the one that interferes and make only one interfere. If you were closer, I have a jig on my drill press but you are not. The flanges do need turned down for the 5 lug drums or rotors. Expect about $25-$30 per axle. The 5 lug are usually 1/2 studs instead of the 6 lug 7/16". You probably have to get new studs either way. Go with the aftermarket if you need something else to break before an axle. A 73-87 that already has a limited slip can save hundreds for the total package --- like TX says above.
dennislbrooks is offline   Reply With Quote
