Old 04-23-2006, 04:07 AM   #1
el curioso
el curioso's Avatar
700 R 4 In a 69 C10
Any one know whats involved in getting a 700R4 to function propely. Cuz the Po on my 69 Just slapped it on and didn't do any thing to make it function properly.
I recently replaced the t.v cable (Trottle valve Cable) so now it shifts properly but there is no over drive in it and I was told that It's controlled through an electrical solinoid.
Any info on how to wire it will help.
Thank You In advance
el curioso is offline   Reply With Quote
Old 04-23-2006, 04:14 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 700 R 4 In a 69 C10
no... it is controlled by the TV cable. How did you adjust the cable?
Old 04-23-2006, 12:16 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Like Longhorn said...cable. The wiring is for the T/C lockup. That may be what you are missing.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-23-2006, 02:21 PM   #4
Deuce
Deuce's Avatar
lowburb is doing this conversion as we speak. He is using a "painless" harness for the lock-up function. He said it looked to be a very nice kit.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-23-2006, 03:09 PM   #5
70GMCer
70GMCer's Avatar
Here's some good info......
http://purplesagetradingpost.com/sum...o/700R4p1.html
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-23-2006, 04:32 PM   #6
Injected68LS1
Injected68LS1's Avatar
Here's a link explaining the TV system; http://www.tvmadeez.com/article/index.php
Also check out; http://www.bowtieoverdrives.com/index.shtml
You need to make sure that you have the electrical system connected so your torque converter locks up when in 4th. If it doesn't you can burn up your trans in a hurry. It doesn't hurt to install a temp gage into your drain plug.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 04-24-2006, 03:05 AM   #7
el curioso
el curioso's Avatar
Opened the throttle, with the cable discconected then pull cable to engadge then press button on tv cable. Do you have any part number for the painless harness?
Thank the rest of you for the links.
Old 04-24-2006, 04:44 AM   #8
Longhorn Man
if you have an intake and/or a carb that did not come from the same vehicle as that tranny.. then that may not work (probebly won't work) and is probably the root of your shifting problem.
I hope you are able to park it untill this is resolved becouse it won't talke long to destroy the tranny.
Old 04-24-2006, 03:18 PM   #9
el curioso
el curioso's Avatar
Its's currently parked but my other question is should I get a tv cable for a 700r4 in a chevy 350 Or which cable should I get. I know that this tranny came from a chevy astro van with a 4.3.
Old 04-24-2006, 03:37 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
I wouldn't mess with the guesswork of trying to get the right TV cable off a used vehicle. Almost everything GM made had a 700R4 in it from about '83 to '92 or '93. Everything from caprices to camaros to trucks to vans and they were all set up different and most had different brackets, some were carbed, some FI, some throttle body...etc... Your best bet would be to save up about $80 and buy the TV made EZ cable from bowtie overdrives. It takes all of the guesswork out of installing the cable. All you need to tell them is what carburator you have.
Bowtieoverdrives.com
I can tell you from experience (trans blew after 5K) that proper TV cable adjustment is VERY important. Hope this helps you .
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
