Old 04-24-2006, 11:36 AM   #1
lilbobone
no spark
i have an 86 c10 truck sometimes it gets spark and sometimes it dont. ive changed the distributer steering columb check wires what else could it be?
lilbobone is offline   Reply With Quote
Old 04-24-2006, 12:00 PM   #2
86 GMG
Re: no spark
86 has a computer controlled spark has your truck been modified from that if so check that area.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 04-24-2006, 08:22 PM   #3
SSC's76
No No
SSC's76's Avatar
Re: no spark
Like 86 mentioned it has the CCS (BS) so it will have a plug in on the back passenger side of the distributor and the spark control box (ECU) will be under the dash in the gove box area. It can casue a drop in spark if unplugged. Now if you changed the distributor did you change the coil as well? A bad coil will cause both dizzys to do the same thing. Also the 3 wire plug in on the drivers side of the distributor that attaches to the cap can have loose terminals inside breaking contact. Pull the dust cover off the cap and take a test light and check/probe around where that plug in attaches with the dust cover off, you do do this from the top. You should have 12V power on the far ends the middle will be ground, make sure the ground strap is in there too since your there.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 04-24-2006, 10:14 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: no spark
Read the paert at the bottom of this page about removing the ESC:
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
I just finished a conversation a few minutes ago with somone on another board. Removing the ESC functionality from his distributor fixed a similar problem on his. Just a thought...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-25-2006, 11:35 PM   #5
SSC's76
No No
SSC's76's Avatar
Re: no spark
Slonaker
Thanks, thats actually very interesting and usefull! I usually just do a reversion conversion and chop the plug. I dident know you could solder the two wires togather and keep the IGN module alive but now that I think about it the b and g wires are a bridge for the one circut. Now Ive got some spare modules for future HEI builds!
Old 04-26-2006, 08:19 AM   #6
lilbobone
Smile Re: no spark
thanks for all the help. i took out the ecm and wires and now it runs good.thanks again for all the help.
