Junior Member
manual to power steering conversion?
I did find someone who said he had done this, and should have emailed him directly since I can't find the thread now. Possibly shortie, something with an s
Re: manual to power steering conversion?
I took the power steering box off a '75 when I pulled the motor out of the same truck to put in my '69. The stock motor should support a pump with the correct brackets.
I did have to notch my bumber mount to clear the steering box, but that was way easy. Last edited by jimmydean; 04-27-2006 at 06:58 PM. |
Green club
You might be asking about me, I just did this a very short time ago.
When I bought the truck, it did come with a very nice 72+ power steering box, but nothing else. I scoured the local pick and pulls to find a doner 71 with all of the brackets and bolts (important to take these too) and located the right hoses at my local Kragen auto parts store. I did however have to modify the stock exhaust manifold bracket because I have headers but one can buy an adapter through Summit I believe. I chose to use my grinder for a tab removal and use a solid spacer for the bolt that goes into the manifold. I think overall I have $80 invested, not including the box which came with the truck. great improvement, I can actually turn into a corner over 10mph without breaking a sweat and drifting into the other lanes ![]()
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
I like Manual, feels like I getting a workout without going to the gym.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
Questionable
just an FYI the driver side bumper support (goes diagonal from the frame) is different on the 67-68 for non-power steering trucks. it may be different on 69-70. you will need to grind a notch for clearance to bolt the bumper support back on.
other than that, you might look in the FAQ if you haven't already ... or if nothing there, use the forum search feature and search for the word "steering" and you should be able to dig through the posts and find several on the topic. to use search, hit the back button in your browser, look at the top of the list of threads and up on the right-hand corner of the thread list you'll see "Search this forum". that will let you specifically search in this forum only for posts. good luck. i'm doing the coversion also, but mine has a little bit of a different flair, so i can't help much.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
For trucks that are drivers I use the newest box I can get for cheep. My pick up has a box from an 87 p.u. The newer box quickens the steering. On my Blazer its getting a 2wd box from an 89 Burban. (going crossover steering) As far as the lines go with the newer boxes they seal whith an O ring, but you can use the output fitting from a new style pump on the old style pumps.
AFAIK, you can use the power steering brackets that use the motor mount bolt for a brace to avoid having to use a pwr strg bracket that uses the exhaust manifold. Still available new, either GM or aftermarket. I can give you an expert source for all you steering conversion needs if you desire. New parts, only though.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Good info here. Thanks.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
