Old 04-28-2006, 10:43 AM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
batt. ground strap
ok guys,
i know this is a simple question, but since i am putting stuff back on i wanted to just double check... i am believing that the neg. batt. cable gets bolted to the frame??? i have a '72 chevy truck i am wanting to bolt the cable back to the fact. location, but i can't remember where exactly it was bolted to could someone tell me where on the frame the neg. bat. cable goes to the frame? i think it is the hole next to the curled up lip part on the pass. side frame.. next to the lower water hose. could someone please let me know....
thanks!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 04-28-2006, 11:01 AM   #2
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Re: batt. ground strap
I think that hole in the curled-up lip on the frame is for a hold-down that clamps the positive battery cable in place as it runs down to the starter.
My ground strap from the negative terminal is attached directly to the cylinder head. It might not be the original location, but someone else who knows this stuff hands down --like CPNE--will jump in and clear it up for you...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 04-28-2006, 11:28 AM   #3
1969k10stepside
I think mine was bolted to the manifold.
1969k10stepside is offline   Reply With Quote
Old 04-28-2006, 12:55 PM   #4
biglou55
Yes it is grounded to the motor- ex. or in . manifold or to any bolt on the head (bolt on the backside of alt . or ps. pump. any of the above will work.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 04-28-2006, 03:18 PM   #5
rodstored-72
chevy truck fan
thanks!
i think now that i have been thinking about it... it was bolted to the alt. bracket. which i dont have now because of the serp. setup. but i am wondering if it can be hooked up to the frame???? i think that if i could hook it up to the frame it wouild look cleaner. but i can also hook it to the ac comp. bracket too i guesss. any other thoughts on a good place to connect the neg batt. cable???
thanks again!!!
rodstored-72
Old 04-28-2006, 03:52 PM   #6
jimmydean
jimmydean's Avatar
Mine is hooked to the frame just bellow the battery tray.
jimmydean is offline   Reply With Quote
Old 04-28-2006, 04:26 PM   #7
Medicanman71
Medicanman71's Avatar
You should have a back up also, not just one. Or the current will find a weak link over time and fry your batt. Ask me how i know..
Medicanman71 is offline   Reply With Quote
Old 04-28-2006, 05:27 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can hook it to the frame. Make sure you have a real good ground cable connected from the engine/trans to the frame too though. You can put it wherever suits you, as long as it's there.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-28-2006, 09:22 PM   #9
Blue85
Oilfield Trash
Blue85's Avatar
I would hook it directly to the motor, just to be sure the starter has a good ground.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-28-2006, 09:28 PM   #10
355
355's Avatar
The bolt hole directly inline with yhe fuel pump rod is my choice. Then make sure you have a strap or at least # 6 AWG connection to the frame for all of your lights, solenoids, etc to work
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 04-28-2006, 10:33 PM   #11
truckdude239
truckdude239's Avatar
mine bolts to the cylider head
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-29-2006, 10:49 AM   #12
william 70 c/20
remember in a DC system the path is - to +..electrons are negatively charged and are attracted to the + side of the battery..have good grounds and plenty of them.i have a - battery cable with a large cable and small pigtail..cable to engine(head) and pigtail to fender.
william 70 c/20 is offline   Reply With Quote
Old 04-29-2006, 10:49 AM   #13
mplex2000
mplex2000's Avatar
Best bet would be one from batt to frame, and one from motor (say the cylinder head) to the same spot on the frame. That way all the other stuff on the truck doesn't have to pull it's ground thru the engine, then the frame, that have a direct connect to the frame, and so does the engine.
mplex2000 is offline   Reply With Quote
Old 04-29-2006, 11:29 AM   #14
rodstored-72
chevy truck fan
thanks guys
i am going to do the last suggestion right now. i would really appreciate it if anyone else looks here to help or give ideas .... please see my newest post. i am really wanting to start my truck this weekend.. please help me!!!
thanks for the great input.
rodstored-72
