Old 04-29-2006, 08:22 PM   #1
shelby987
shelby987's Avatar
disc/drum proportioning valve?
I am looking at updating from drum/drum to disc/drum brakes. I purchased a power booster a couple of months back, and it came with a proportioning valve that looks nothing like my drum/drum prop valve, so I guess I am assuming that its a disc/drum valve, but can anyone give me some pics. The tubing locations appear to be in different locations, so I will have to rebend some plumbing, and I want to try to keep it looking relatively correct.
I also have two different mc's one is much larger than the other, am I better off using the larger of the two to keep the fluid cooler?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 04-29-2006, 11:37 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: disc/drum proportioning valve?
I am using this proportion valve by using I mean it is loosely bolted to the master cylinder. I plan on hopefully finishing everything up tomarrow.
http://www.classicperform.com/Store/...ruck/PVKS2.htm
As for master cylinders you also need a disk/drum one. I'm not real sure what you have but would recomend one of these
http://www.autozone.com/servlet/UiBr...KES&PageSync=5
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-30-2006, 08:02 AM   #3
pound41
My 70 blazer was power drum originally. Someone had installed a newer front end. The power boosters are pretty much the same. The prop valve is different. The line fittings are different and the bracket that holds the valve are different. I bought new lines and was going to install them. but they didn't match up correctly. Not sure if that had to do with the front end. So I think one of your original lines will fit the prop vale and one is too small. I went to the plumbing store and got a male/female adapter. For me tthat was the quickst fix. It has worked fine.
pound41 is offline   Reply With Quote
Old 04-30-2006, 03:18 PM   #4
69face
69face's Avatar
most aftermarket prop valves are 1/8" pipe thread to 1/4", bo reducers and fitting are available at most good parts stores(autozone is not a good parts store, lol). I used an aftermarket adjustable wilwood valve and it works fine. I bought it from jegs or summit for about 40 dollars shipped.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
