Old 04-30-2006, 12:32 PM   #1
englishrodder
englishrodder's Avatar
Eaton Pinion Nut wont budge :-( Ideas??
Hi All,
Well my new oil seal arrived to stop my pinion leaking, downside is I have tried for 3 hours to remove the pinion nut with no luck
I tried my air wrench, 3foot long breaker bar, even had this on with an extra tube still no luck! Also but the bar on and tried to push the burb so the axle might undo it.
Im really struggling now as I need to get it fixed,
May be a dumb question...is it a LH or RH thread?
Cheers
Dave B
69 Suburban 3 Door
32 Pick-up
englishrodder is offline   Reply With Quote
Old 04-30-2006, 03:28 PM   #2
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
Re: Eaton Pinion Nut wont budge :-( Ideas??
its a regular thread, just real tight, hasnt been off in 30 plus years. You need to shock it hard to get it broke loose, it's hard to get leverage when you are under it, but remember, you can pull harder than you can push, so make sure you are on the correct side of it and pull down with a cheater pipe on your breaker bar. you may have to jack up one side so the handle sticks out from under it far enough to stand on it or even stomp down on it. if you need to keep it from turning, put the ujoint keepers on and wedge something into the yoke that will catch the frame so it cant turn. if all else fails do like the coyote and purchase a pinion nut blaster from ACME. best of luck, ron
Superron21 is offline   Reply With Quote
Old 05-01-2006, 10:46 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
You do know that you need to get the pinion nut back on the exact number of turns that you take it off? This is what sets the depth of the pinion in the ring gear. Too loose or too tight and they will be junk in a matter of miles.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-02-2006, 04:56 PM   #4
englishrodder
Hi there,
Thanks for the replies, yeah I know about setting the pinion etc.
Tried again for 4 hours, the sucker still wont come un-done....Grrrhhh
Cheers
Dave B
69 Suburban 3 Door
32 Pick-up
Old 05-02-2006, 05:15 PM   #5
70rs/ss
70rs/ss's Avatar
Originally Posted by englishrodder
Hi there,
Cheers
Try heat around the bolt to see is the housing won't expand just enough to turn loose of the bolt. righty tighty lefty loosy!!
70rs/ss is offline   Reply With Quote
Old 05-03-2006, 01:14 AM   #6
masterbeavis
Having issues
masterbeavis's Avatar
Heat on the nut, ice on the pinion
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 05-03-2006, 12:10 PM   #7
70rs/ss
70rs/ss's Avatar
I thought it was a bolt into the housing? If so then heat the housing and the bolt backs out? If you heat the bolt and ice the housing the bolt expands and the housing shrinks and it becomes even tighter, if I have this wrong (which I might as I have never personally worked on one of these) LMK, but I have seen picts and if memory serves me correctly the advice I gave is correct.
Old 05-03-2006, 04:24 PM   #8
jku72
I did one a while ago, no cheater bar in the world will work, the only thing that finally worked was a man sized industrial impact gun, after heating the nut with a torch.
To make this easier, you can unbolt and remove the pinion flange/pinion assembly and take it to a truck garage. I mean a big truck garage.
Its a bear.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-03-2006, 06:26 PM   #9
el curioso
el curioso's Avatar
While a go I took mine to a big rig shop and the guy there heated the nut and rapidly added water until it was cool to the touch then a torque wrench till the nut berly moved wrote the force down and then a 1/2" impact from there. New nut with some anti sieze to keep things easy for the gear change.
el curioso is offline   Reply With Quote
Old 05-05-2006, 05:39 PM   #10
BULIT
The best tool for the job imo is an 1/2 inch Electric impact gun , I sure wouldnt use heat on it
BULIT is offline   Reply With Quote
Old 05-07-2006, 11:18 PM   #11
wibilly
wibilly's Avatar
i did mine today,man was that sucker on there, i had my whole chunk out tried holding the yoke with a big pipe wrench and turning nut with a 3/4 "breaker bar. yea right.so i got the bob-cat set the bucket down on the pip wrench slipped a pipe over the breaker bar and lifted the bobcat. so i tried heating the nut with a little propane tourch and adding weight to the bobcat bucket, still no go oh i forgot to mention the 600 ft/lb inpact that did nothing. so i broke out the blue wrench and heated her up good then she finialy broke loose in i finished her off with the impact. factory service manual makes no mention of marking and reinstaling in same posistion for an eaton but i did mark it for referance, it says toquqe it to 200 ft/lbs.itsays nothing about setting or ajusting backlash but lists .005-.008 as perfered and min of .003 and max of.012". is backlash ajusted by shimming or what? and how do you check it? i havent assembeled it or checked it yet because i need to get a speedy sleave for my yoke
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-08-2006, 01:11 AM   #12
wibilly
wibilly's Avatar
chiltons truck manual has a very detailed eaton overhaul section, it seems the pinion yoke nut does not set pinion depth it states 325-400 ft/lbs fo 11/8 pinion shaft
Old 05-13-2006, 04:13 AM   #13
englishrodder
Hmm interesting info about the nut not setting pinion etc.
Still trying to get the nut off
I even jacked the burb up set ul a breaker bar on the nut then slowly lowered the burb back down hoping the weight would add enough leverage on the bar and then undo the nut.....Err no chance...breaker bar just took the full weight and movement from the nut....
Also used my air gun still no use...
Think its off to a truck garage!
Dave B
69 Suburban 3 Door
32 Pick-up
Old 05-18-2006, 09:56 PM   #14
JAKES 68GMC
Aluminum slot wheels rule...
Did you try some PB Blaster or Deep Creep on the threads. I swear those two oils work good on frozen stuff.
JAKES 68GMC is offline   Reply With Quote
Old 05-18-2006, 10:01 PM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
You will have to heat it to loosen the locktite that is on the nut threads.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-20-2006, 10:17 AM   #16
I got all bound up eatin`pinon pine nuts once.That what I get for listening to Ewel Gibbons.
Listen to Phantom Dually,get that sicker hot.
Old 05-21-2006, 05:10 PM   #17
englishrodder
OK going to try some heat this week, anyone know where I can get a new Pinion nut from that ships to the UK? Appears Rock Auto dont do them
Cheers
Dave B
69 Suburban 3 Door
32 Pick-up
Old 05-22-2006, 09:18 PM   #18
I can`t tell.Is your Suburban a 10 or 20 series?Someone could set you up,I`d think.
Old 05-23-2006, 11:15 AM   #19
englishrodder
Hi , Its a C20 350 4 Speed but with 8stud HO52 rear and 8 stud front as well.
Dave B
69 Suburban 3 Door
32 Pick-up
Old 05-24-2006, 12:54 AM   #20
4x4Poet
Does Randy's Ring & Pinion ship overseas?
http://ringpinion.com/
Need someone to call them toll-free?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-24-2006, 08:57 PM   #21
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Let me contact them. I work just down the street from them and buy a ton of parts from them. I will call them on Thursday afternoon when I get to work.
oldiron is offline   Reply With Quote
Old 05-24-2006, 11:00 PM   #22
pumpkin
pumpkin's Avatar
If you hit the side of the nut with an air chisle or just a hammer and chisle, it will in time loosen. Something else to try is put a breaker baron the nut, with the bar on somthing solid, and push or pull the truck, mabee even hitting the end of the bar and soccet with a BFH (big hammer) Be sure to take precautions not to get run over. I have yet to have a nut, or bolt beat me. If you have any more troubles bring it by and I'll get it off,,, NO CHARGE
pumpkin is offline   Reply With Quote
Old 05-25-2006, 06:23 PM   #23
oldiron
oldiron's Avatar
englishrodder, Just got back from Randy's Ring and Pinion. That nut is torqued to 175 ft lbs. After 30 + yrs you will need to soak it with some good penatrating(sp) oil for a couple of day then heat it up. Also contact a machine shop and see if they have any pentatrating wax that also works.
If all fails go down to the local pub and find someone alot larger than you to help.LOL.
Good luck
Old 05-28-2006, 05:06 PM   #24
englishrodder
Thanks guys for the info, Tried the heat and the oil. I just cant get enough swing on the breaker bar as I cant get the burb high enough.
Its booked into a mates garage so he can put it up on the 4 poster, that we we can both swing of a large breaker bar....
More updates in a week or so...
Cheers
Dave B
69 Suburban 3 Door
32 Pick-up
Old 06-14-2006, 03:32 AM   #25
englishrodder
Well its finally fixed, 1.5hrs at a local garage!
Now I can get on with sorting what drop coils/spindles i need etc.
Thanks for all the help/info guys
Dave B
69 Suburban 3 Door
32 Pick-up
