Old 04-30-2006, 07:46 PM   #1
Leks
Am I screwed?
The 327 I was planning on using has bad heads (not rebuildable). Do I have to go and try and hunt them down or can I use another set of heads like off of a 350 or even 305?
I was told by gramps I could use any other head but sometimes I think the Milwaukees Best gets to him!
I figured I'd go for some profesional advice befor I sink the money into this rebuild kit I planned on ordering!
http://www.adicustoms.com/
Leks is offline   Reply With Quote
Old 04-30-2006, 07:53 PM   #2
speed
Junior Member
speed's Avatar
Re: Am I screwed?
You can use a set for 305, unless you want to loose some compression. Any stock type SBC head will physically bolt on.
The other option would be to use a set of higher c/r pistons with a pair of 350-400 heads.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
speed is offline   Reply With Quote
Old 04-30-2006, 11:41 PM   #3
Karl Hoh
A little east of nowhere
Re: Am I screwed?
You can use 305 heads but you will lose alot of compression. 305 heads are 76cc, 327 heads are 64cc, if you can't find small chamber heads to replace the unrebuildable ones, you have to do the math & install domed pistons to compensate for the larger combustion chambers.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 05-01-2006, 08:29 AM   #4
Leks
Re: Am I screwed?
is this true even when going oversize on the bore?
or what about jetting the carb a little different!
This sounds like its going to be a nightmare, I may just try and find a 350!
Old 05-01-2006, 08:41 AM   #5
86 GMG
Re: Am I screwed?
call some local machine shops they usually have heads laying around ready to install. here in tulsa there is one called tuter (sp?) it is around downtown i think third street talk to terry he is an aquantince and ownes the place.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 05-01-2006, 09:40 AM   #6
Leks
Re: Am I screwed?
Ya I know who you are talking about! I use Lucidos, and a guy here at works wife works for Moritz. The problem is these guys want an arm and a leg for heads let alone a 327 head!
Old 05-01-2006, 09:49 AM   #7
86 GMG
Re: Am I screwed?
yeah agreed and lucito is freakin awsome but he dont have much of a surplus that shop of his is the first and only machine shop that i would eat of the floor im not familiar with 327's other than most people i hear talk about them run 194 heads not sure what the deminsions are as far as valve sizes i can make some phone calles and see what i can find through my conections around here ill keep you posted 86gmg
Old 05-01-2006, 10:11 AM   #8
Leks
Re: Am I screwed?
If you dont mind!
I know thats what Im doing on my lunch break today!
Old 05-01-2006, 12:47 PM   #9
SCOTI
SCOTI's Avatar
Re: Am I screwed?
Some Vortec heads should work well w/a 327 sbc. Have you considered them?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-01-2006, 12:50 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Am I screwed?
Ditto on what Scoti says. I would go for a decent set of Vortec heads.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-01-2006, 01:59 PM   #11
86 GMG
Re: Am I screwed?
leks tuder machine has 327 heads ready to bolt on except for the springs and
rockers 300.00 with a core since yours are bad 400.00. i may be able to get a better deal if we were to go together maybe like stasted above an aquantence buddy deal if were lucky. so far thats the best i can come up with. personally buying a set from some one and then rebuilding them would be about the same if not more. i will pm you my cell number to hook up if you want
Old 05-01-2006, 02:39 PM   #12
SSC's76
No No
SSC's76's Avatar
Re: Am I screwed?
Theres nothing special about the 327 heads even if they were double hump heads the only advantage they would have over a set of 416 305 heads would be the valve size and the 305 heads have smaller combustion chambers and actually larger ports where it matters.
Get any set of SBC heads and they will work fine.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-01-2006, 06:18 PM   #13
speed
Junior Member
speed's Avatar
Re: Am I screwed?
350 = 76CC
327 = 64CC
305 & 267 = 58CC
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
Old 05-02-2006, 08:46 AM   #14
Leks
Re: Am I screwed?
350 = 76CC
327 = 64CC
305 & 267 = 58CC
I found a set of 350 heads Im guessing they will work?
Old 05-02-2006, 12:07 PM   #15
82c10
needin' money
Re: Am I screwed?
yes, any set of sbc heads will work, just won't run as good as if you put the smaller combustion chambered heads on
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
