05-01-2006, 08:30 PM | #1 |
Active Member
Rear End Code
I Was Wondering If Any Part Of The Axle Number Code Tells You If It Is A Posi. Rhaw3442 Is The Number On A Rear End I Have. I Know Rha Is The Code For A 3.07. What Do The Other Numbers Stand For. Thanks
05-01-2006, 08:46 PM | #2 |
Re: Rear End Code
The 3 letters are what indicates what the rear end is
If yours is RHA then that is a 1972 3.07 Posi numbers for 72 are RAA RAX RAZ RGS RGY RHB RHG RHT RHX RJY RPH RPW RRS RRW
05-04-2013, 06:34 PM | #3 | |
Re: Rear End Code
I'm trying to find a 3.07 5 lug rearend, and it wouldn't hurt my feelings for it to be a posi. I think it should reach sticky status if someone posted all the axle codes for 1967 through 1972 including posi status, year of the code, etc... My own research indicates that all 1971 codes start with a T, and 1972 codes start with an R. All pre-1971 codes are two letters instead of three. I've found most of the pre-1971 codes, but everything after that seems to be secret information, or nobody really knows. Thanks for your time.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
05-04-2013, 09:49 PM | #4 | |
The Older Generation
Re: Rear End Code
These would be for all ratios. The 3.07 would be RHB. I have all of the codes but I don't know if they would be readable if posted them because of the way I saved them. I guess I could try posting them in a new thread and see what happens... LockDoc
05-04-2013, 10:32 PM | #5 |
Re: Rear End Code
That would be sweet. I've searched all the threads for code definitions, and only found the most basic common ones. I've found listings for all the 1967-1970 codes, and even a listing of all the 1971 codes, but nothing on the 1972 codes. If you start a new thread I'll contribute what I have if you don't have them all.
I can't believe how many people have asked, and got minimal responses, or none at all. Most only want to define one code for the individual. 90% of those are common codes they could have found easily if they would have done a search. I think if someone made a point of collecting all the codes and put them in one place, many people would be very pleased. Thanks
05-04-2013, 10:58 PM | #6 |
Re: Rear End Code
1971
axle code model App Ratio TNB CE20 4.10:1 TNW CA 30, PS-PE 30 4.57:1 TNZ CA-PA 30 4.10:1 TOU CA20 4.57:1 TOT CA 20 4.10:1 TPA GE 30 4.57:1 TPB GE 30 4.10:1/No Spin TPC GA 30 4.57:1/No Spin TPD GE 10 3.07:1 TPE GE 10 3.07:1P TPF CA-PA 10 3.73:1P TPG CA 10 4.11:1P TPH CA 10 3.07:1P TPI CE 10 3.07:1P TPJ CE 10 3.07:1P TPK KA 10 3.73:1P TPL CE 10 3.07:1 TPM CA 10 3.73:1P TPN CA 10 4.11:1P TPO CA 10 3.07:1P TPP CE 10 3.07:1P TPR KE 10 3.07:1P TPW KE 20 4.10:1 TPX KE 20 4.10:1/No Spin TPZ KE 20 4.57:1 TRM CD 50 4.86:1/6.61:1 TRN CE 30 4.10:1 TTF CA 20 4.10:1/No Spin TTJ PS-PE 30 4.57:1 TTK PS-PE 30 4.57:1 TTL PS-PE 30 4.57:1/No Spin TTM PA 30 4.10:1 TTN PS-PE 30 4.10:1/No Spin TTO PS-PE 30 5.14:1 TTP PE-PT 30 4.10:1 TWI CA 20 4.10:1/no Spin TVF CA-PS-PE 30 5.14:1/No Spin TVI CA 30 5.14:1/No Spin TVL CA 30 4.57:1/No Spin TVN CA 30, PS-PE 30 4.57:1/No Spin TVO CA 30 4.57:1/No Spin TVS CA-PS-PE 30 5.14:1/No Spin TVT CA 30 5.14:1 TYS CA 20 4.56:1 ----GM PARTS DIVISION, GENERAL MOTORS CORPORATION - CHEVROLET - 72TL---- For example...
05-04-2013, 11:28 PM | #7 |
Re: Rear End Code
