dumb question
Did these 4X4 Blazers have front and rear swaybars? Mine doesnt have either.
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's Last edited by makovai; 05-03-2006 at 01:04 AM. |
Iron Thunder
Re: dumb question
i don't know about the swaybars, but i do know, there is no such thing as a dumb question. if you don't ask you won't know.
Re: dumb question
NO, not from the factory.
Some folks are using sway bars from mid 70s trucks and modifiyng them to fit/work on our year Blazers. Check the FAQ, should be some info there I would hope.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Re: dumb question
I put some very flexy Alcan front springs on my '71. To compensate for the tippy nature of the soft springs I also installed a mid-70s swaybar. As 71jimmy mentioned, I think there's a FAQ on this. I know BobK made some nice ones. Here are a couple of pictures of the mounts I fabricated and a link to more if you are interested.
Link to fabricating swaybar mounts
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 05-03-2006 at 09:09 AM. |
Re: dumb question
![]() I was just making sure i wasn't missing some suspension, that is posed to be there. I'll probably work on adding them myself when i make my torque bars. I can kill tippy and axle wrapup all in the same project ![]()
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
Re: dumb question
Nope no sway bars on First Gen Blazers
I added a front one from this company: http://www.addco.net/ But now that my K5 is a trailer queen I don't use it anymore.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
