05-03-2006, 02:15 PM | #1 |
Header Wrap
Can you wrap headers installed on the truck?
The Cause and The Reason: The Cause is starter heat soak The Reason, headers are welded to pipes.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
05-03-2006, 02:21 PM | #2 |
its all about the +6 inches
Re: Header Wrap
You are WAY better off with a heat shield.
Header wrap will shorten the life of a header by at least 50%... if not more. You oughta look into a starter too. |
05-03-2006, 02:32 PM | #3 |
Questionable
Re: Header Wrap
header wrap is supposed to hold moisture to the header and cause them to rust out exponentially faster.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
