05-04-2006, 08:48 AM | #1 |
looking 4 a sbc alternator bracket L/S
Looking for a left side set of alternator brackets for a sbc. I'm changing cabs from a non air cab to a air cab. Thanks
05-04-2006, 10:40 AM | #2 |
Re: looking 4 a sbc alternator bracket L/S
I have a set that is chrome plated along with a chrome plated alternator. Brackets are $45 shipped to your door. I will sell both brackets and alternatort shipped to your door for $80. Lower bracket has a small amount of rust as the picture shows. Tha alternator works fine.
I will be without a computer until Friday night so cannot respond again until then. Thanks. |
05-04-2006, 11:15 AM | #3 |
I may have an extra, will look this evening.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
05-05-2006, 12:03 AM | #4 |
Thanks Ridgeback I have a new alternator just need the brackets. Thanks for looking Rick
05-05-2006, 02:31 PM | #5 |
Rick1971, I have a set. Do you need just the cast bracket or the bracket and strap? I have both and will separate if needed.
$35.00 shipped to your door for both pieces. Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
05-05-2006, 09:32 PM | #6 |
I guess I need both pieces. Will this work with a long water pump as I am changing cabs and I have a long water pump on the 400 sbc. I can get you a money order or send it paypal. Thanks Rick
05-07-2006, 12:22 AM | #7 |
Rick - I don't know about fitting with long water pump. I think the bracket would fit the head but I don't think the pully would line up using the LWP. I don't want you to be unhappy if it doesn't fit. You have to make that call.
Let me know - Bob
05-07-2006, 01:53 AM | #8 |
Thanks Bob, I'll keep looking fr a bracket for a long water pump. Thanks Again
05-07-2006, 11:19 AM | #9 |
Watch out for your cornhole !
Long water pump setups used passenger side alternator mounts exclusively, until much later when they went to serpentine pulley arrangements.
