Old 10-05-2002, 01:14 AM   #1
Paul Clark
Alternator Bracket?
Is there an alternative way to mount the alternator on a 350? I have that curved metal piece of strap stuff. Something is out of whack (what is a whack, anyway?) and I think it's causing stress on the alternator. It sounds wrong, and it wobbles a bit.
Is there another brace?
Pulleys out of...you know.
Paul Clark is offline   Reply With Quote
Old 10-05-2002, 01:26 AM   #2
mikep
Used to have a truck
mikep's Avatar
I use a long water pump and all the long water pump accesories that go along with it. Makes finding accesories, brackets and pulleys a whole lot simpler.
No truck :-(
mikep is offline   Reply With Quote
Old 10-05-2002, 01:32 AM   #3
bigjimzlll
bigjimzlll's Avatar
do a search for alangrove industries,, they have great brkts
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-05-2002, 11:53 AM   #4
Desert Rat
Desert Rat's Avatar
If you have the correct stock ones you shouldnt have any problems i get $30 for the 2,and i have all the pulleys,and ps brackets left in a pile.if intrested EMAIL me gmcrat427@yahoo.com
if you need long pump i have the pulleys $10 both,AC brackets $25,Alt$10,PS$15.
Desert Rat is offline   Reply With Quote
Old 10-05-2002, 12:54 PM   #5
bigjimzlll
bigjimzlll's Avatar
DR...if you use headers, and have an aftermarket intake..and use a short water pump, can you still use stock brkts?
Anderson,CA
Old 10-05-2002, 11:29 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Big Jim, yas, it will work with your aformentioned add ons. I had my old CST/20 Longhorn set up like that. It all bolts up to the head.
Old 10-06-2002, 12:25 PM   #7
Desert Rat
Desert Rat's Avatar
Yes the short pump stuff works IF you have the later bolt holes in the heads.thats where the alt brackets mount,headers and aluminum intakes dont interfere.Thanks
