![]() Join Date: Sep 2001
Check my torque specs:
For 3/4 ton front suspension:
Idler arm support bolts (3/8"): 30 ft/lbs (I guessed at this one) Idler Arm-to-support: 60 ft/lbs Idler arm-to-drag link: 60 ft/lbs Pitman Arm nut: 175-180 ft/lbs (damn that's alot) Pitman Arm-to-drag link: 60 ft/lbs Upper control arm bushings: 90 ft/lbs Upper control arm center bolt stud nuts: 80 ft/lbs Upper ball joint bolts (5/16"): 15-20 ft/lbs ...so what about the 3/8" bolts that hold the sway bar brackets to the frame? How 'bout the bushing bolts for the sway bar?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
