05-10-2006, 09:24 PM | #26 |
Re: Progress pics - air system, not far...yet
Thanks for the info.Goodluck!
05-10-2006, 10:58 PM | #27 |
More progress tonight. I was able to drill the holes in the crossmember for the bulkheads.
The first two pictures are of the driver's side, I haven't finished this side yet. The second two pictures are the passenger's side, I was able to get both of these fittings in tonight.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-10-2006, 10:59 PM | #28 |
Here are the emergency fills for the individual bags. I have it set up so I can fill the air tanks with a schraeder valve, or I can fill each individual bag with a schraeder valve.
06-08-2006, 10:59 AM | #29 |
Anymore progress?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
06-08-2006, 01:42 PM | #30 |
Front bags are in, I still have to run the lines to the front bags, wire the system, and run the lines to the gauges. I haven't gotten to spend much time out there, but I am getting close. I will put some new pictures up this weekend.
06-09-2006, 11:57 AM | #31 |
Where did you get the bulk head fittings? Do you have a part #? I want to use something similar on my front crossmember. Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-09-2006, 01:43 PM | #32 | |
06-18-2006, 11:40 PM | #33 | |
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
06-18-2006, 11:46 PM | #34 |
www.hoseandfittings.com
Funny you posted tonight, I was going to update this old thread. I had play with the crossmember bulkhead fittings, I cut some pipe at an angle so I could get the fitting to point at the bag a little straighter. I have everything plumbed now. Sometime next week I hope to pressurize the system so I can start chasing down any leaks that I may have. I still have to try to figure out how to mount my York compressor to the passenger side. I also have to finish the wiring. Slowly but surely!
06-19-2006, 12:17 AM | #35 |
let me know how you mount your york. Mine is still sitting in the box.
06-19-2006, 06:46 AM | #36 |
blood type; Retumbo
hey Shawn, if you have an extra york bring it down and I can fab up some brackets for ya. I'll use Lefty as a pattern.
09-11-2006, 05:13 AM | #37 |
A guy with a truck
Get anywhere with the York yet? Tossin' around ideas of an EDC too...
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-11-2006, 12:10 PM | #38 |
Using conduit is a great idea! I might need to do that. I don't understand why you ran a bulkhead fitting for the crossmember though. Looking at the install diagram I have, they just ran a hose from the bag to the valve.
I am still waiting for my brackets and drop spindles, then I can do mine! Nice work. |
09-11-2006, 12:56 PM | #39 |
Outlandish Trends - FL
I didn't see where bulkhead ftgs were necessary either. I just used a 90* fitting, 1/2" NPT x 3/8" DOT push-to-connect. It also swivels which makes it nice. Once you tighten the fitting into the bag, you can still swivel the 90 to where you need to run the line. It was a piece of cake. It was a little difficult to get my hand in there to push the line into the fitting, but once I got it in there I was good to go.
I also can't see why you needed to cut holes in the floor to get to the upper bag mounts in the rear. Granted I've got a P/U but I didn't even remove the bed to mount the bags and plumb everything. The hardest part was drilling the 1" hole for the fitting on the bag port to clear through the frame. Again, here I used a 90* fitting just like on the front and then ran the line down the frame to the rear valves. I can't imagine that the Blazer frame back there would be that much different, is it?
-Bret 67 short-fleet sold! |
09-11-2006, 01:20 PM | #40 | ||
I couldn't get me hand up in there to bolt the bags in. The bolts where spaced far enough apart that one was really close to the frame and the other close to the cup. Since there was already a huge hole in the floor cut by the PO I decided to go that route. If I could have had my truck on a lift I think I could have gotten by without cutting the holes.
09-11-2006, 02:01 PM | #41 |
09-11-2006, 04:28 PM | #42 |
Does this board member want to make another one?
09-12-2006, 12:42 AM | #44 |
Why would this only work for a long style water pump?
09-12-2006, 06:49 AM | #45 |
A guy with a truck
Pulleys are in a different position fore/aft about 3/4" with the different w/p set-ups.
Looks like a bolt on solution for some. Too bad I have a supercharger sitting right there...
09-12-2006, 11:02 AM | #46 |
how do I know if I have a long water pump?
09-13-2006, 04:17 AM | #47 |
A guy with a truck
Look between the back of it and the timing chain cover; if there is a 3/4" gap, you have long accessories. If the pump is resting on the cover, you have short. -Chris
09-13-2006, 11:04 AM | #48 |
THanks gringo.
Camaro_thunder- I tried to contact your bracket supplier, but had zero luck. I did some research and found that he doens't make these anymore. Any other ideas?
09-14-2006, 01:21 AM | #49 |
A guy with a truck
May be able to do something with this: http://www.easystreetair.com/browsep...r-Bracket.HTML Some assembly required...
09-14-2006, 01:44 AM | #50 |
thats funny, who would buy this? If you have to make the bracket yourself why couldn't you drill the holes?
