Old 05-13-2006, 04:52 PM   #1
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Getting a 1970 K/20 Burb!!!!!!!!!!!!!!
Here's the story. A couple months ago I found this old 1970 yellow and white Chevy K20 Suburban at the junkyard. It was all original except the 350 had been replaced by a 454! I bought the seat(black vinyl), dash pad(also black), and fan shroud out of it, and I came back for some other stuff a week later and it was gone. Somebody bought it and it sat about 20 miles out of town on some guys land. What happened was, this guy let his friend that bought it keep his trucks on his property and he left 'em there way too long. So what happened? The property owner got tired of 'em being there and called the same junkyard the burb came from to pick it up. We went to the junkyard today and Dad saw it sitting way in the back, and I told him we gotta buy it before it gets crushed/stripped. Get this, the guy at the yard is selling it to me for $300, with a clear title!!!!!!!!!!!!!!! It still has the BB/tranny/x-fer case and both axles. The rear is the Eaton HO52, the front should be a D44. I don't know if it is original, I didn't look for brake drums. It had the red lockouts on it so it might not be. It has four 16.5 slot rims that are painted steel? with 8.75-16.5 tires. It has a real big bumper on the front that I think had a winch before. The rear bumper is pretty big too. It has rust problems at the top corners of the front and rear roof but it's real solid on top and not dented or real rusty, most of the truck has original paint. It has the tailgate and lift hatch, all glass windows are good. Has original gauges, radio, black non-tilt auto column and wheel, black door panels and all rear trim panels, and the glovebox lid with the 4x4 sticker, and it also has the original 4x4 shift knob, I think it has the NP205 t-case. It's weird though, it has front heat and rear A/C. The compressor is gone and so is the heater box, the dumbass that bought it had all kinds of crap thrown inside and messed the center seat up, and I guess he's the one that took the heater box. No biggie, I have a spare. The engine looks like it'll run with some new plugs and basic stuff, not sure about the tranny or t-case. I'll have to check all the grease levels and gears, etc before I try to drive it around. I should have this by next Friday!!!!!!!!!!!! Can't wait!!!!!!!!
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-13-2006, 05:41 PM   #2
big blue 72
Re: Getting a 1970 K/20 Burb!!!!!!!!!!!!!!
Cool, will go good with your other '70!!!!!
big blue 72 is offline   Reply With Quote
Old 05-13-2006, 09:00 PM   #3
RANDY COX
RANDY COX's Avatar
cool cain't wait to see pixs,my 70 K/10 also has the red lockouts.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-13-2006, 09:34 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
What a deal!!!
Frizzle Fry is offline   Reply With Quote
Old 05-14-2006, 01:27 AM   #5
4x4Poet
Sounds like a runner. The tranny and xfer case probably leak, but only need an oil change. Unlikely that they'll prove problematic to get the truck back on the road. The interior parts and body are another matter.
I sure hope that 454 runs. That would be sweet. Drain the block and flush the block from the thermostat neck through the block drains before running it, though. Just spray garden hose thru while blocking the water pump intake. New thermostat, too. Probably needs a new water pump.
Maybe have the radiator cleaned by a rad shop. Only $36 here if no repair needed. They use an acid tank with ultrasound waves to loosen any crud in the tubes. Much better than just flushing.
Make sure the tank has good fuel. Rust and congealed gas will clog a carb fast. Best to drain it and have it also cleaned by a rad shop. Perhaps, sealed, too. Then get to the brake hydraulics. Who knows what you'll find there, too. Safety first.
Looking foward to pics.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-14-2006, 07:43 AM   #6
Great advise from 4x4poet.You`ll also need a black dashpad,seat,and fan shroud.
Old 05-14-2006, 12:26 PM   #7
Thanks for the tips guys. I'm gonna put the seat and dashpad back in it when we get it home. I kept the old seat from my truck and fixed it and put a new green saddle blanket seat cover on it, just never got it put back in the truck. The first things I'm going to do are try and fix the rust areas around the roof, but I wanna try to get it running before I do that! The engine looked complete, had an air cleaner on top of the Quadrajet so at least the carb should be clean enough to fire the engine up. The gas cap was on the filler neck too so hopefully the important stuff is in good shape. I'll change the oil, flush the cooling system, change the fluid in the tranny, t-case, and both diff's., and get the gas tank cleaned. Man it's gonna take some work. The brakes are gonna be fun, I don't know if the return spring for the pedal was broke or if it was disconnected but the pedal was to the floor. I will take a lot of pictures of it when we get it home. I'll probably end up pulling it with my truck since it's only a couple miles to my great Uncle's house, I'll bet were gonna draw a lot of attention. A green truck pulling a yellow Suburban.
RJD
Old 05-14-2006, 07:06 PM   #8
RANDY COX
RANDY COX's Avatar
pixs,pixs,we need pixs man the suspence is killing me.
1964 BBC 402 4x4
Old 05-14-2006, 09:25 PM   #9
I won't have 'em till Saturday, try not to think about it too much.
RJD
Old 05-15-2006, 01:11 AM   #10
4x4Poet
Originally Posted by Robert1970C20rstbukt
I won't have 'em till Saturday, try not to think about it too much...
Old 05-15-2006, 08:29 AM   #11
Can you at least draw a picture
Old 05-15-2006, 03:26 PM   #12
bagged91
Out draggin'
bagged91's Avatar
lol!Draw a pic!
Good find... How rusty is it???
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 05-15-2006, 09:04 PM   #13
JAKES 68GMC
Aluminum slot wheels rule...
If they are cool looking slot wheels, they should be aluminum. Sounds like a sweet deal. Is it already street legal, or is it going to need alotta work?
JAKES 68GMC is offline   Reply With Quote
Old 05-15-2006, 09:58 PM   #14
My handwritin ain't too good, so a drawin picture is out of the question. I'll take the camera and see if he's open tomorrow.
bagged91, it's not in good shape in the roof areas, but it's fixable and is in way better condition than the cab on my truck. Overall the body is in good condition with the exception of the roof.
Jake, I know they were slot wheels, but they were rusty and had been painted white. Sounds weird but that's what me and Dad saw. They are 16.5" wheels that are 8.25" wide and they have 8.75-16.5 tires that are at about 30% tread and holding air. There was another one in the spare tire holder in the back that had a big blowout in the tire, so there's a complete set of 5 wheels. I'm keeping those wheels on there since they look cool and I don't have any spare 8 lug wheels or tires. I'll paint 'em silver when I can get around to it. This Burb is gonna be a whole new project. Full brake system needs to be gone through, fluids changed, cooling system flushed, probably 2 hours worth of cleaning the interior out, etc. I sure as hell hope that big block runs good!!!! There was all kinds of crap thrown inside, me and Dad were cleaning it all out at the junkyard there, so most of the big stuff is out except for the stuff that's staying like the gauges, radio, glovebox lid, and all the hardware that was taken loose. This guy had a big diesel tank from the back of a pickup in there with another gas tank shoved against the center seat(seat is OK!), junk engine gaskets, etc. I found a big logging chain in the back and some hard hats, this used to belong to a construction company according to the records that were in the glovebox. There was a spare belt for the engine that had "Old Yeller" written on the paper sleeve too. Pics will be here soon, stay alert guys!
RJD
Old 05-18-2006, 08:57 PM   #15
JAKES 68GMC
Tell ya what, since I'm a nice generous kind of guy, I'll buy the 'Burb off from you for $301, therefore you will be making profit. Not only that, I'll let YOU ship it up here to Maine, in to my driveway, at no cost to me. Sound good?
Old 05-19-2006, 10:36 PM   #16
Hell no! I should have it here tomorrow, but we're having a big paintball war at a ranch for one of my friend's graduation party. So it's gonna take awhile longer, as usual.
RJD
Old 05-20-2006, 10:05 AM   #17
JAKES 68GMC
Have fun, and get the pics ASAP.
Old 05-21-2006, 07:17 PM   #18
I knew some crap like this was gonna happen............Yesterday morning I went and checked it out again, yes it has the original front axle and the 205 T-case. I would've bought it last week but Mom wouldn't let Dad buy it for me. Well the guy at the yard said someone wants the steering column and steering box. I was pissed, and I didn't have enough $$$ and still don't. Damnit I hope nothing's missing off of it..............Will post back ASAP when I find anything out.............
RJD
Old 05-21-2006, 08:55 PM   #19
JAKES 68GMC
Damn that sucks. Hope its in one piece when you get it.
Old 05-22-2006, 12:23 AM   #20
4x4Poet
Uh oh. Mom ain't keen on the obsession.
Old 05-22-2006, 05:26 PM   #21
Well the guy never came to get the parts!!!! YES!!!! Dad went out there this morning to talk to him, and the guy at the yard is gonna make sure nobody messes with it. Dad's gonna drop off half of the money for me tomorrow while I'm at school. It'll be home soon!!!!!!!!!!
RJD
Old 05-22-2006, 05:38 PM   #22
JAKES 68GMC
Well thats good. Congrats.
Old 05-22-2006, 06:59 PM   #23
Thanks dude. I can't wait to hear that BB rumble, it already has a dual exhaust with long glasspacks that's still in good condition. I might have trouble with the pass. side hub, I couldn't get it to go into the free position with just my hands. The engine will crank over, when I looked at it Saturday morning I turned it with a breaker bar. The tranny and transfer case go into all gears/ranges too. It has a TH350, hopefully it'll work OK. There was clean red fluid on the dipstick, and the engine was full of oil too but it needs to be changed bad.
RJD
Old 05-22-2006, 08:06 PM   #24
RANDY COX
RANDY COX's Avatar
Whew that was close,now go get that sucker so we can see it.
1964 BBC 402 4x4
Old 05-22-2006, 09:28 PM   #25
I'll take pics if the yard is open late, he usually closes at lunch time and I get out of school at 3:37. Our last day of school is thursday so it'll be friday at the latest!!!!! Class of '06 rules!!!!!!
RJD
