Old 05-13-2006, 07:43 PM   #1
Ricks1971
Ricks1971's Avatar
sbc 400 alternator bracket qustion?
I'm putting a 400 small block in my 71 4X4. I changed the cab to a air cab so I need to change the alternator to the drivers side, The 400 also uses a long water pump. My question is what driver side alternator brackets would I use on this application. I found a set but the guy was not sure if they would work on a long water pump. Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 05-13-2006, 09:17 PM   #2
Bob Moore
Re: sbc 400 alternator bracket qustion?
As Tex said, I don't think there is one. Hope someone can prove me wrong for your sake.
Can you use the short water pump on the 400? I don't know what other brackets you already have or not. The a/c on the pass side stock on the 67-72. In 73 when they went to long waterpump on trucks the a/c went to drivers side.
What is the result you want to achieve? Stock look? 400 stock look?
Put out what want and the board can probably come up with an answer.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 05-13-2006, 10:09 PM   #3
corn
I think you would be better off switching everything over to the long pump style setup. Id think you could just have a set of longer ac hoses made so you could mount that on the drivers side instead of the alternator...
corn is offline   Reply With Quote
Old 05-13-2006, 11:13 PM   #4
wibilly
wibilly's Avatar
i was just wondering the same thing. is there a crank pully to run the short pump on the 400 balancer? i too wanna run air and the stock look but with a 400
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-13-2006, 11:32 PM   #5
Ricks1971
Ricks1971's Avatar
Thanks guys, I have the new compressor and bracket from vintage air to fit on the right side plus the water pump and all the pulleys. I'm not much into getting the right look but rather something that will work good.
Old 05-13-2006, 11:47 PM   #6
corn
Heres an option...
http://www.yearwood.com/store/produc...&s=&id=ALA201L
Old 05-13-2006, 11:56 PM   #7
Ricks1971
Ricks1971's Avatar
Thanks cornfed63 I saw those mounts. I saw these brackets on ebay and was thinking of using shims to bring the bracket out abit to compensate the half inche difference from the short water pump to the long one.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
What do you think?
Old 05-14-2006, 12:13 AM   #8
wibilly
wibilly's Avatar
i personaly would like to keep the short water pump and all acc. if posable
Old 05-14-2006, 12:21 AM   #9
ed455
Captain Ed
What do you think?
Don't do it!!!
That's our friend from Lone Oak, TX. The chrome will be crappy if you get the parts at all. BEWARE!!!
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 05-14-2006, 12:50 AM   #10
Ricks1971
Ricks1971's Avatar
thanks for the heads up on this guy.
