Old 05-15-2006, 07:48 PM   #1
alfeefish
coil springs
I have a 67 1/2 ton 2wd with a 283. I want to drop the front end .I need to know how much to cut out of a coil spring for a 2 inch drop? I'm going the cheap way out.
alfeefish is offline   Reply With Quote
Old 05-15-2006, 08:01 PM   #2
Green Machine
Green Machine's Avatar
Re: coil springs
Your're going to get several opinions on this but to me the only way the spring will fit properly is to cut exactly one coil off, no more, no less and see what you get.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-15-2006, 08:07 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: coil springs
I cut 1 1/4 coils and got about 2.75" drop.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-15-2006, 08:45 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: coil springs
one coil should be about 2 inches, and I agree, it'll only fit properly if you do a full coil.
