Old 05-16-2006, 04:43 AM   #1
local13hutch
MEMBER
local13hutch's Avatar
WTB. k/5 r upper hatch hard wear only
I have a good hatch and tee handle with both side supports. I nee inside rods and both side latch pieces that bolt to hatch and lock and release I think I have every thing else.
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
Old 05-16-2006, 03:58 PM   #2
jamie72
jamie72's Avatar
Re: WTB. k/5 r upper hatch hard wear only
i got them,hows 20.00 and shipping??
if interesed send me a pm
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-16-2006, 06:51 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
OFF TOPIC - Your Siggy
What is a 71 K2 Blazer?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-17-2006, 05:30 AM   #4
local13hutch
MEMBER
luv2xclr8..I have heard the 2wd drive blazers called k/2 and i've also heard them called c/2 ...but they are definately not k/5 ....Can any body shead some light on this subject....
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 05-17-2006, 05:41 AM   #5
local13hutch
MEMBER
jamie72...Thank you for the quick response ....pm sent
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 05-17-2006, 06:42 AM   #6
I guess the name thing is kinda odd.They`re all called K/5 on the nameplate.But,technical a 2wd Blazer would be a C/5.Just like in 69/70 when a base level truck was a C/10 or C/20 on the nameplate,even if it was a 4wd K/10 or K/20.So,those would be a C/10 K/10,etc.So,I guess a 2wd Blazer would be a K/5 C/5.If I had a 69/70 base truck,I`d call it a K/10 and ignore the nameplate,basically it`s got no name.If I had a 2wd Blazer,I`d call it a C/5,right or not.That says what it is in my mind,that`s what names are for.It`s like my`90 Blazer,screw GM`s name,it`s a K/5,not a V1500.
Old 05-17-2006, 08:48 PM   #7
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I have both rods only (cheap) if you need them.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 05-18-2006, 02:26 AM   #8
local13hutch
MEMBER
badpeanut...I think i've got it covered from ''jamie72'', But thank you just the same. I still may end up needing them so ill keep you posted.
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 05-18-2006, 02:37 AM   #9
local13hutch
MEMBER
jamie72...problem with ebay address..pm sent...local13hutch...
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
