05-17-2006, 07:49 AM | #1 |
TH 350 shifts a bit late...adjustable?
It stays in first and second longer than most I've driven and I was wondering if that's adjustable? I'd rather not take it into a shop if I can avoid it...anyone know how/if I can do it myself?
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
05-17-2006, 08:11 AM | #2 |
Re: TH 350 shifts a bit late...adjustable?
Kinda opposite from what I want but some modulators are adjustable, might check for a vaccuum line leak to it, also you may have to replace the modulator --in expensive--check Summit. There are some trans gurus on this forum.
05-17-2006, 02:43 PM | #3 |
its all about the +6 inches
There's a few things you can do. Pull the vac line off the modulator on the bottom of the tranny, and stick a small flat head screwdriver in there. If you feel a screw head, crank it in to lower the shift point, screw it out to raise the shift point. (I think that's right)
If there is no screw, follow the vac line, see where it goes. If it goes to a ported manifold port, pop it off and put it on a ported vac connection. |
05-17-2006, 03:47 PM | #4 |
71 GMC 454/TH400
Also you can adjust the throttke valve control cable (kick down) contrary to popular belief they have some control over the situation.
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
05-17-2006, 05:52 PM | #5 |
not a throttle valve.... that's only on overdrive... just a kick down cable. You get them confused and you can waste ppl's time and money.
The kick down cable, if adjusted too tight, can create this problem, but in all reality, it is pretty hard to accidently do this. |
05-17-2006, 07:33 PM | #6 | |
71 GMC 454/TH400
05-17-2006, 09:51 PM | #7 |
no...I'm sorry if it sounded cockey...
hell, you brought up a point no one else had mentioned. |
05-17-2006, 09:59 PM | #8 |
i replaced my modulator recently and it advised to adjust it by the bolt on the bracket holding it in...I put it in and loosened it to smooth out the shifting. The best part was, nothing spontaniously burst into flames...lol
05-18-2006, 06:01 AM | #9 |
that's a new one by me.
05-18-2006, 08:51 AM | #10 |
Thanks Longhorn Man....I'll try that this weekend.
The TV cable is only on the 2004R & 700R4 4 speed autos....I've had one of each before and hated them with a passion.
05-18-2006, 09:04 AM | #11 |
Actually, the TV cable will be on anything with a lock-up torque converter. Including the 200c, 3sp, and some late model TH350.
05-18-2006, 09:10 AM | #12 |
Another thing I am not fond of....lock up TC's.
05-18-2006, 04:58 PM | #13 |
Myself, that is inacurate. There is a kick down cable on the TH200C and on the TH350C, not a throttle valve.
05-18-2006, 09:46 PM | #14 |
The kickdown cable is connected to the throttle pressure valve in the valve body, You are both correct.
05-18-2006, 11:06 PM | #15 |
Msgt USAF Ret
Here is a website that explains a lot about transmission shifting.
http://yarchive.net/car/transmission.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-19-2006, 11:19 AM | #16 | |
05-19-2006, 12:21 PM | #17 |
On my TH-350 it will kickdown into 1st. Is that only on some models?
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
05-19-2006, 02:46 PM | #18 |
350s will kick inot 1st.
you may have me on the 200... I haven't even seen one since the 80's, and I was a kid back then. |
05-19-2006, 03:32 PM | #19 |
Yeah the 200's were kinda junky , but they were ok for lighter, low horsepower applications.
05-19-2006, 03:58 PM | #20 |
yeah, it was funny when my buddy's chevette tore up a TH200. I couldn't believe it. That thing was so slow it was unreal.
05-19-2006, 04:11 PM | #21 |
The 'Ill-Fated '86 MCSS' had a 2004R....it was rebuilt when I had the motor out. I bought a 330hp HO 350 roller-cam crate motor [another mistake] and after we got it in and took it out for it's maiden voyage, the tranny tanked on the first shift into second gear. There went $1600.
Before the MCSS I had an S-10 Blazer 4x4 with a 700R4 in it. That rebuild totaled over $600 [in '92]. While the 700's are much better trannys, to this day I destest GM's 4 sp autos from the lowly and vastly cheap 1980's cars and trucks. You could give me one, but I'd have it on ebay before you got back home.
