Old 05-18-2006, 01:19 PM   #1
AWEGS72
AWEGS72's Avatar
Turnsignal switch does not cancel itself
My turnsignal switch on but will not click off after I have turned a corner. It used to only do it when for LH turns. Then the other day something clicked inside and now it does the same thing for RH turns. So now I have to remember to cancel it every turn.
What is the problem?
Thanks in advance
Andy
AWEGS72 is offline   Reply With Quote
Old 05-18-2006, 01:30 PM   #2
Medicanman71
Medicanman71's Avatar
Re: Turnsignal switch does not cancel itself
Sounds like it could me the Turn signal return-nut
sorry, idk
Medicanman71 is offline   Reply With Quote
Old 05-18-2006, 01:36 PM   #3
john
member #16
john's Avatar
Sounds like the cancelling springs are broken. Pull steering wheel to replace. Sorry no pic but parts house should have them.
john is offline   Reply With Quote
Old 05-18-2006, 01:37 PM   #4
AWEGS72
AWEGS72's Avatar
I see LMC lists a Canceling cam. $9.95. I think I'll check with GMC Paul's first though.
Old 05-18-2006, 01:39 PM   #5
sdmahr
sdmahr's Avatar
Head to any auto parts store and get a turn signal cam kit. Get the complete kit with springs etc. Remove the steering wheel horn button and install.
When I took mine apart it was a mess. No springs, plastic sleeve on shaft was worn down, (has ribs that contact the springs for cancelling). In your case, it sounds like the spring holder and/or springs are worn out. Pay close attention to how it comes apart.....instructions with the kit are for wasting paper !
Kit is about 10-15 bucks if memory serves me correctly.
GOOD LUCK !
sdmahr is offline   Reply With Quote
Old 05-18-2006, 01:52 PM   #6
Green Machine
Green Machine's Avatar
If you get lucky, you jus tneed to replace the little spings, just fixed my right side the other day, that was all it was, simple and cheap.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-18-2006, 01:58 PM   #7
Orange
Licensed to Thrill!
Orange's Avatar
It looks something like this (not exact part)...
They have them on the HELP! aisle in the parts store if I remember correctly.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-18-2006, 02:06 PM   #8
AWEGS72
AWEGS72's Avatar
72 SAME AS 73? Parts place has 1973 in stock but has to order 1972 in? I see some parts interchange through the years,but not sure on this one as I dont have interchange on this part.
Old 05-18-2006, 04:08 PM   #9
Werewolf
Woof?
Werewolf's Avatar
I don't think so; '73 uses the new column with the ignition built in. Fairly different if memory serves.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 05-18-2006, 04:51 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You only need the springs most likely. The dealer should have them, they are like 39 cents each or something.
