05-18-2006, 11:02 PM | #1 |
PROJECT 7DEUCE
New floors thread..
I am finally starting my new floor installation and am doing this major surgery as a 1st timer hope to have all this finished up by monday but we'll see how bad the rust is underneath the floors... BTW this is the first truck I have ever seen with bondo on the floors the p.o. was a dumb azz.. Here the pics from today didnt get much done as I ran out of cut-off wheels(note to self look before you start)
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-18-2006, 11:05 PM | #2 |
PROJECT 7DEUCE
Re: New floors thread..
Check out the p.o.s patch work all of it was coverd with bondo... The sheetmetal that surrounds the bolt that holds the body on is pretty much gone..
05-18-2006, 11:10 PM | #3 |
PROJECT 7DEUCE
Notice the bolts in the t-case crossmember is gone the other one did not even have a nut on it??? Anybody ever seen a brace like the one bogger welded to the inside of the rocker box???? Is the support on the bottom of the floor section I cut out factory or so p.o. add on???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 05-18-2006 at 11:15 PM. |
05-18-2006, 11:17 PM | #4 |
PROJECT 7DEUCE
Looks like I gonna need to fab up a front cab brace also.. The rocker boxes are in great shape and only have a hole in the rear flat section about the size of a half dollar so far s o good..
05-19-2006, 09:18 AM | #5 |
That should keep you busy for a while. Sure will be way better when you're done! Question is, what kind of shape are the front cab supports in? Please keep us posted with the progress!
The 'Z' shaped support under the floor is factory... as is the rod that's welded in diagonally in the torsion box.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 05-19-2006 at 09:22 AM. |
05-19-2006, 09:47 AM | #6 |
67 is sold
Lots of work. Im holding out for the full reproduction floors due out in a month or so
05-19-2006, 10:13 AM | #7 |
No,I DON'T have Tourett's
Looks like fun.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
05-19-2006, 11:33 AM | #8 |
Project Junkie! Fishing Poor!!
We just went through that same repair on my 2 wheel drive Blazer. Just take your time, leave the top on and it will turn out great!! WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
05-19-2006, 04:24 PM | #9 |
It sure is fun to see what the PO has done for repairs before you. The Crew cab I am doing was filled with fiberglass where ever the PO found rust. I would rather deal with bondo, little heat for a tortch and it pops right out! Are you getting into your rockers at the same time or just the floors?
Kevin LFD Inc. |
05-19-2006, 04:31 PM | #10 |
The LuvShack Garage
Progress is cool
05-19-2006, 04:56 PM | #11 |
Those pictures make me wanna slap somebody!
Good luck and keep posting progress pics. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
05-19-2006, 05:00 PM | #12 | |
and if you don't have a top???? Good thing i don't have to replace as much |
05-19-2006, 10:08 PM | #13 |
Done by Monday huh?
Why is it that the P/O's never seem to get it right? |
05-19-2006, 10:09 PM | #14 |
PROJECT 7DEUCE
Not sure if I am gonna do the rockers or not they seem pretty solid no progress today sprinklers for the house were on the todo list ..
05-19-2006, 11:29 PM | #15 |
which patch panel do you need to get to get the lip that runs along the bottom of the door? is it the rocker? or the floor pan?
EDIT: the lip that the seal goes on. Last edited by nathan_454; 05-19-2006 at 11:29 PM. |
05-20-2006, 12:38 AM | #16 |
PROJECT 7DEUCE
I believe that is on the rocker pannel patch..
05-22-2006, 10:05 PM | #17 |
PROJECT 7DEUCE
Hey kurt its monday and the floors are no where near done ha ha ha... Here are a few pics from today worked on it for about 2 hours or so this is not a weekend job if you want it done right I guess..
05-23-2006, 09:55 PM | #18 |
PROJECT 7DEUCE
Got lots of work done today but have some questions for those of you who have done this work before... Heres a few of the pics from 2day.. Looks like I am gonna have to break up a new floor brace..
05-23-2006, 10:00 PM | #19 |
PROJECT 7DEUCE
Check out that killer patch job by the p.o. on the bottom you can see the bondo(who the hell puts bondo on the floor boards??? Pyle of sheetmetal cut out.. Atleast the rocker boxes look good..
05-23-2006, 10:09 PM | #20 |
PROJECT 7DEUCE
Heres the only rust in the rocker box,very easy fix.. Is this plate needed to be welded to the floor comming off the bedfloor??? Anyone have good pics of how this should attach?? It is solid amazingly. Should the lip on the patch pannel go underneath the rocker pannel or stick up like it does here?? The lip I am talking about is the one my finger is on??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 05-23-2006 at 10:12 PM. |
05-23-2006, 10:10 PM | #21 | |
Always the way... Great progress, keep going! |
05-23-2006, 10:16 PM | #22 |
PROJECT 7DEUCE
Heres where I have a few questions... Do blazers have the inner backing plate like a truck does?? Or is that what is included on the floor patch pannel?? Kurt you planning a vacation to oregon anytime soon?????
05-23-2006, 10:25 PM | #23 |
That's exactly what I'm going to have to do to mine. Thanks so much for the pics, it gives me a better idea of what I'm going to have to do. The front cab supports look really accessible from the top. That's good to know because I was considering taking the tub off to get to all of that. What did you use to cut the floors out?
05-23-2006, 10:26 PM | #24 | |
05-23-2006, 10:30 PM | #25 | |
